Transmission question, Brake bands on first gear |
Bartlett 914 |
Sep 22 2010, 02:35 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I am going through a transmission. First gear is supposed to have only 1 brake band. All other gears have 2 brake bands. Upon inspection, I find that my first gear is setup the same as all the other gears. It has 2 brake bands and the same stop blocks as the other gears. I really don't understand why Porsche did first different except to save money on 1 brake band. I do understand that synchronization is on the down shift and two may not be needed. Question is, should this matter? Is there some advantage to the way first was setup by Porsche?
charliew |
Sep 24 2010, 01:26 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I have had worn trannys that at a stop you could first go into second then put it in first easily but they were not the 914, you might go into rev then 1st though at a stop.
Lo-Fi Version | Time is now: 18th June 2024 - 05:45 AM |
