> Intermittent wiper not working
michaelmoo
post Sep 15 2010, 04:26 AM
Ok I have the intermittent relay and a washer pump on my car. First ever thing is wired correctly and making good contact. Second, I know the order of the wiper switch: all the way down is intermittent, then off, then slow, then fast (well faster than slow…). Pulling the switch you get like 4 or 7 swipes and the pump comes on. That is how it is suppose to work.
Here is what I get: all the way down is nothing, then off, then slow, then fast (well faster than slow…). Pulling the switch I get the 4 or 7 swipes and the pump comes on.
Thoughts? If the relay was bad would the 4 or 7 swipes still happen with the pump?
Mike
Bartlett 914
post Sep 15 2010, 06:50 AM
You cannot have both intermittent wipers AND a washer pump. Disconnect the washer pump and you will see the intermittent wiper function work. The problem is the resistance of the washer pump changes the timer function in the intermittent wiper relay.
markb
post Sep 15 2010, 03:38 PM
914less :(
QUOTE(Bartlett 914 @ Sep 15 2010, 05:50 AM) *
I put in a pump years ago, and later added the intermittent, but never did get it to work. Maybe this is why. (IMG:style_emoticons/default/dry.gif)
Bartlett 914
post Sep 15 2010, 06:25 PM
QUOTE(markb @ Sep 15 2010, 04:38 PM) *
I have done a lot of work on this project. The intermittent relay has 3 modes. Off, on for several seconds and on for 1 second switching off for about 5 seconds.
The first is obvious. We need to turn off the wipers. The control wire is the brown with a black stripe. In the off position it is held at ground. This connection is the one from the mounting screw that holds in the wiper switch.
Moving to the intermittent position (full down) this connection is open. In this position the connection must be greater than 15K ohms. In this position, the relay has the on for a second and off for 5 or so seconds. When it switches on for a second, the wipers move out of the park position. They continue until they are again parked and wait for the next pulse from the intermittent relay. Because the control wire is open for this mode, if the screw is not tightly holding in the wiper switch, we can get ghost wipes.
The third position is +12 volts when pulling back on the wiper switch. Pulling back opens the valve for washer solvent flow and applies +12 to the intermittent relay. The relay will hold as long the 12 volts is applied and the wipers will operate continuous. When the 12 volts is removed, the relay will hold for a few seconds longer running the wipers for several additional sweeps.
Because the intermittent mode uses an open condition and if we install a washer pump, the resistance of the washer motor acts as a ground. Therefore the intermittent mode will not work. The open must be greater than 15k and a washer pump is around 50 ohms.
I was just able to make both modes work on my car. I installed a circuit card that has a relay, 2 transistors and 3 resistors. The input impedance for this circuit is greater than 27 K ohms. This allows all functions to work.
JFJ914
post Sep 16 2010, 08:41 AM
QUOTE(Bartlett 914 @ Sep 15 2010, 08:25 PM) *
Can you explain how you powered the pump so it caused this condition. I want to add the 911 pump and thought of replacing the water switch with a micro switch and separate 12v and grd at the pump.
Bartlett 914
post Sep 16 2010, 08:57 AM
QUOTE(John Jentz @ Sep 16 2010, 09:41 AM) *
Can you explain how you powered the pump so it caused this condition. I want to add the 911 pump and thought of replacing the water switch with a micro switch and separate 12v and gnd at the pump.
There are different switches. Earlier ones did not have a contact. The connector for the switch has 5 positions. If one is open then the switch is an earlier one and this won't work. If you do not have the intermittent relay, you can directly connect the Brown ? Black wire to a washer pump. One side of the pump is grounded. The wiper switch will supply 12 volts at the Brown / Black wire when pulling back on the stalk. If you want both intermittent wipers and an electric washer pump. install the intermittent relay and wiring harness and build the small circuit I provided to drive the washer pump.
motomadness1947
post Sep 25 2010, 02:14 PM
error
michaelmoo   Intermittent wiper not working   Sep 15 2010, 04:26 AM
vsg914   Since 914's did not come with intermittant wip...   Sep 15 2010, 05:56 AM
John Jentz   Since 914's did not come with intermittant wi...   Sep 15 2010, 08:57 AM
914Sixer   Pull your steering wheel and make sure all the 4 s...   Sep 15 2010, 06:33 AM
Bartlett 914   You cannot have both intermittent wipers AND a was...   Sep 15 2010, 06:50 AM
markb   You cannot have both intermittent wipers AND a wa...   Sep 15 2010, 03:38 PM
Bartlett 914   You cannot have both intermittent wipers AND a w...   Sep 15 2010, 06:25 PM
John Jentz   [quote name='markb' post='1371281' date='Sep 15 2...   Sep 16 2010, 08:41 AM
Bartlett 914   [quote name='markb' post='1371281' date='Sep 15 ...   Sep 16 2010, 08:57 AM
motomadness1947   error   Sep 25 2010, 02:14 PM
motomadness1947   You say there are two different switches and the ...   Sep 25 2010, 02:15 PM
michaelmoo   Mark, Thanks. I will try unhooking the pump and se...   Sep 15 2010, 07:16 AM
Tom_T   :agree: And any dealer could install one for a b...   Sep 15 2010, 10:08 AM
jim_hoyland   My washer works the stalk is pulled back, like you...   Sep 15 2010, 10:29 AM
michaelmoo   Mark, Do you have pictures of the circuit card? I...   Sep 16 2010, 03:57 AM
Bartlett 914   Mark, Do you have pictures of the circuit card? I...   Sep 16 2010, 08:41 AM
76-914   Thanks Mark. I had converted to an electric pump a...   Sep 16 2010, 08:17 AM
Bartlett 914   Here is a copy of what I made for having both inte...   Sep 17 2010, 08:11 AM
Bartlett 914   I found an error in my schematic. I added a resist...   Sep 22 2010, 07:55 AM
Literati914   [b]You cannot have both intermittent wipers AND a...   Nov 25 2024, 10:38 PM
Steve   I have a 75 with the 924 wiper thingy. I remember...   Nov 25 2024, 10:46 PM
Literati914   I have a 75 with the 924 wiper thingy. .. OK, b...   Nov 26 2024, 12:09 AM
- Lo-Fi Version Time is now: 31st December 2024 - 10:46 PM
