sfrenck |
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region ![]() ![]() |
Testing my used 3-port fuel pump for the first time (along with new hoses, cleaned injectors, etc.). The system won't develop more than 25 psi before the fuel pressure regulator.
I went ahead and clamped the fuel return line after the FPR (to rule out a bad FPR), and then even clamped the "R" port out of the fuel pump to make sure a faulty fuel pump check valve was not to blame - still 25 psi (also, the system holds around 20 psi for an hour while I grab a beer and swear I'm not going to work on the car anymore today). Am I down to a "bad" pump that just doesn't get up to pressure? |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Testing my used 3-port fuel pump for the first time (along with new hoses, cleaned injectors, etc.). The system won't develop more than 25 psi before the fuel pressure regulator. I went ahead and clamped the fuel return line after the FPR (to rule out a bad FPR), and then even clamped the "R" port out of the fuel pump to make sure a faulty fuel pump check valve was not to blame - still 25 psi (also, the system holds around 20 psi for an hour while I grab a beer and swear I'm not going to work on the car anymore today). Am I down to a "bad" pump that just doesn't get up to pressure? It would appear that way ................... The Cap'n |
Lo-Fi Version | Time is now: 24th June 2024 - 11:57 PM |
