Dual rear window glass, practical?? |
Chris914n6 |
Mar 21 2004, 03:56 PM
Jackstands are my life. Group: Members Posts: 3,393 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Since the NSX had a 2 pane rear window I was wondering if it would be worth it for the 914? I know the NSX has a vacuum in between to cut sound transmission that would be hard to create.
The 914 has the room on the "ledge" for 2 and a gap (5mm + 5mm + 5mm). fire away (IMG:style_emoticons/default/fighting19.gif) (IMG:style_emoticons/default/chatsmiley.gif) (IMG:style_emoticons/default/smile.gif) |
JeffBowlsby |
Mar 21 2004, 06:24 PM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
QUOTE It would also keep the rear window from fogging. Until the edge seal fqails then it will fog when water gets in. Insulated galss is not a good application for cars, and it would be difficult to accommodate the thickness of that glass assembly in teh rabbet of the 914 rear window. A much better idea is laminated glass...it has a higher sound isolation rating than insulated glass and could be made as a direct replacement for the thickness of the stock glass. Its the same stuff used as windshields. |
Lo-Fi Version | Time is now: 25th September 2024 - 10:59 PM |
