Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,345 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
Since the NSX had a 2 pane rear window I was wondering if it would be worth it for the 914? I know the NSX has a vacuum in between to cut sound transmission that would be hard to create.
The 914 has the room on the "ledge" for 2 and a gap (5mm + 5mm + 5mm). fire away (IMG:style_emoticons/default/fighting19.gif) (IMG:style_emoticons/default/chatsmiley.gif) (IMG:style_emoticons/default/smile.gif) |
GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
If it can be done, it should be tempered so if it breaks there isn't many sharp edges at neck height.
As to the insulated glass, many window builders use argon gas with a reflective heat shield on one of the layers of glass. The two panes (or three)of glass are sealed around the edges with silicone and a needle is inserted between the panes. The air is sucked out and a squirt of argon is put in to displace any moisture. This stops the glass from getting cloudy when it heats up. |
Lo-Fi Version | Time is now: 24th June 2024 - 11:22 PM |
