Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,343 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
Since the NSX had a 2 pane rear window I was wondering if it would be worth it for the 914? I know the NSX has a vacuum in between to cut sound transmission that would be hard to create.
The 914 has the room on the "ledge" for 2 and a gap (5mm + 5mm + 5mm). fire away (IMG:style_emoticons/default/fighting19.gif) (IMG:style_emoticons/default/chatsmiley.gif) (IMG:style_emoticons/default/smile.gif) |
Chris914n6 |
QUOTE(vsg914 @ Mar 21 2004, 04:26 PM) Well, there is one more small problem. I don't think there's enough room between the glass and the backpad, or side trim peices to go any thicker. I'd look if I had mine in... maybe that's why it fell out in the first place. (IMG:style_emoticons/default/laugh.gif) My car is unique in that the V-6 puts alot of heat into the firewall, softened up the roll seal. My pads can be trimmed since they are getting a cloth covering anyways. Rear pad is now carpet. I'm still looking for a rubber seal to hold the 2 pieces of glass together. Argon injection may be an issue. Oh, I'm still looking into using factory glass if you haven't guessed yet. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 24th June 2024 - 07:38 AM |
