Anyone running 4 pots? I hope I don't, have issues... |
rick 918-S |
Mar 21 2004, 01:05 AM
Hey nice rack! -Celette Group: Members Posts: 20,681 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I installed 4 pistons front calipers and a 19mm master cylinder this weekend. Also removed the "P" valve for the rear calipers and installed a "T" fitting. So the lines were pretty much empty. I added ATE Super Blue fluid and bled the system until I used a quart of fluid. After a day of hunting I managed to locate a friend that had a new quart on the shelf. We continued to bleed the system and added another half quart.
Here's the my issue... After bleeding the system for several hours I still have a low peddle. After the second pump of the peddle the hieght seems good. ( goes from 2/3 sweep to about almost 1/2) Do you think I need to continue to bleed the system or are the 4 piston calipers requiring the extra motion just to fill? Anyone running 4 piston calipers with a 19mm master cylinder? If so how much peddle travel do you have? |
rick 918-S |
Mar 22 2004, 07:59 AM
QUOTE(Brett W @ Mar 21 2004, 08:56 PM) Guys those are not BMW calipers they look like Girling Calipers off of a 240 Volvo. They have the same twin line setup because Volvo had 4 lines running from the master cylinder to the front brakes. These are ATE 4 piston style from a BMW. U had a set of Volvo calipers. They are even bigger the ATE units pictured. |
Lo-Fi Version | Time is now: 28th September 2024 - 04:15 PM |
