Dual rear window glass, practical?? |
Chris914n6 |
Mar 21 2004, 03:56 PM
Jackstands are my life. Group: Members Posts: 3,393 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Since the NSX had a 2 pane rear window I was wondering if it would be worth it for the 914? I know the NSX has a vacuum in between to cut sound transmission that would be hard to create.
The 914 has the room on the "ledge" for 2 and a gap (5mm + 5mm + 5mm). fire away (IMG:style_emoticons/default/fighting19.gif) (IMG:style_emoticons/default/chatsmiley.gif) (IMG:style_emoticons/default/smile.gif) |
brians914 |
Mar 22 2004, 11:54 AM
Newbie Group: Members Posts: 31 Joined: 16-March 04 From: Minnesota Member No.: 1,805 |
We have put many Lami units in homes where sound was an issue and had great success. You can get Lami in alot of colors also, green, bronze, and two shades of gray (gry & gry lite 14). Also it comes in two different thickness, 3/16 & 1/4. Never build a unit that has a tint on the inboard lite of glass, heat will build up between them and cause it to break. Been there done that. Also if the inboard lite on a insulated unit is not supported well it will sag and leak. Been there also.
Lo-Fi Version | Time is now: 25th September 2024 - 10:54 PM |
