> Creamsicle Project, Still tinkering... now it's running!
poorsche914
post Sep 6 2010, 05:57 PM
T4 Supercharged
I finally decided to tackle getting my LE started and thought the long Labor Day weekend would be the perfect time. I had already replaced the fuel tank and lines up front and had sourced '74 FI parts and bought a new Optima battery. The final piece to the puzzle was a working fuel pump which I got a couple weeks ago.
So this weekend I installed the pump and put power to it. It ran but wasn't pumping fuel up to the engine. I heard gurgling from the tank. Low fuel level. So I added more gas and tried again. Success! Fuel was now being pumped to the fuel rail but there were several leaks. Took care of these and cranked it. Nothing. Pulled two injectors and saw they were not firing. Swapped out harnesses and more of the same. (IMG:style_emoticons/default/sad.gif)
I have both a single progressive and dual 40s. I seriously contemplated pulling the FI and installing the single Weber after a rebuild just to get the car running. After chatting with mipstein I had a few things I thought I should try first. I put power to each injector and they all fired so that took bad injectors out of the equation. I looked over pbanders d-jet page for clues. Somewhere along the way I realized the ECU was not getting power and perhaps the relay board was suspect. Having two extra boards, I picked one, transferred relays, etc and plugged it into the 914's harnesses. Turned the key, let fuel pressure build, cranked it and she fired right up!!! (IMG:style_emoticons/default/mueba.gif)
Vacuum lines, etc aren't hooked up so it revved high before I turned it off. Next step is to hook up all the vac lines (and install new shift bushings, install accel pedal, etc, etc) Goal is to have it on the road for MUSR11 (IMG:style_emoticons/default/driving.gif)
hot_shoe914
post Sep 6 2010, 10:08 PM
on ramp passer
QUOTE(poorsche914 @ Sep 6 2010, 06:57 PM) *
poorsche914
post Oct 8 2010, 02:42 PM
T4 Supercharged
Got a vacuum line kit from AA and installed it last night. Hooked everything up according to the schematic which was very helpful.
Turned the key and it would turn over but not fire. (IMG:style_emoticons/default/dry.gif)
Pump runs for several seconds and then turns off so apparently system is getting pressurized.
Today I tried some starting fluid to see if that would help. Nothing.
Unhooked the advance and plugged the nipple on the throttle body.
Pulled a plug wire and inserted a spare plug to check for fire. Had my son turn the key.
It fired right up (IMG:style_emoticons/default/blink.gif)
Since I was holding a plug wire, I told him to turn it off. Ran about 5 seconds or so.
Replaced plug wire and tried to start it.
Started to fire and then BOOOOOM and a cloud of white smoke out the tail pipe.
Now, it won't crank. The starter just clicks. (IMG:style_emoticons/default/confused24.gif)
Any ideas? Not sure how the BOOM would be related to the starter not working. The motor is not locked up.
dvtorr
post Oct 10 2010, 12:36 PM
QUOTE(poorsche914 @ Oct 8 2010, 12:42 PM) *
is it a click or more like a clunk sounds? Same thing happened to me and Idk if my motor is seized up or not. Right now Im stuck on this.. Figuring out the problem isnt easy! what is a BFH treatment for the starter?
poorsche914
post Oct 10 2010, 12:43 PM
T4 Supercharged
QUOTE(dvtorr @ Oct 10 2010, 02:36 PM) *
For me, it was a click at the starter. I removed the starter and gave it the BFH treatment which is banging on it with a hammer. Whatever was stuck came unstuck and it has been working ever since. (IMG:style_emoticons/default/confused24.gif)
As far as my electrical issue - hooked up the center console gauges and none of them work. Well, except for the clock (IMG:style_emoticons/default/blink.gif)
Any idea what one main thing might be keeping all the gauges and blinkers and dash lights from working? As an added note, the hazard lights work but does not show on the indicator on the tach.
hot_shoe914
post Oct 10 2010, 12:46 PM
on ramp passer
QUOTE(poorsche914 @ Oct 10 2010, 01:43 PM) *
Back up a step. You said you swapped out the relay board. Did the gauges and such work before or after you swapped board?
poorsche914   Creamsicle Project   Sep 6 2010, 05:57 PM
NC_Colfax   From what I have read the single weber is poo and ...   Sep 6 2010, 07:11 PM
PanelBilly   Next week I start stripping mine for a full paint ...   Sep 6 2010, 09:45 PM
hot_shoe914   I finally decided to tackle getting my LE started...   Sep 6 2010, 10:08 PM
poorsche914   Got a vacuum line kit from AA and installed it las...   Oct 8 2010, 02:42 PM
hot_shoe914   Got a vacuum line kit from AA and installed it la...   Oct 8 2010, 05:58 PM
poorsche914   The starter just clicking sounds like solenoid. ...   Oct 8 2010, 06:18 PM
dvtorr   Got a vacuum line kit from AA and installed it la...   Oct 10 2010, 12:36 PM
poorsche914   is it a click or more like a clunk sounds? Same th...   Oct 10 2010, 12:43 PM
hot_shoe914   is it a click or more like a clunk sounds? Same t...   Oct 10 2010, 12:46 PM
poorsche914   Back up a step. You said you swapped out the rela...   Oct 10 2010, 12:57 PM
dvtorr   is it a click or more like a clunk sounds? Same t...   Oct 10 2010, 01:29 PM
poorsche914   Did you ever try to push start your car before yo...   Oct 10 2010, 01:33 PM
poorsche914   After mulling this over and searching the forums f...   Oct 10 2010, 06:53 PM
hot_shoe914   After mulling this over and searching the forums ...   Oct 10 2010, 07:52 PM
Spoke   Could the ignition switch be faulty? Thanks for ...   Oct 10 2010, 08:11 PM
poorsche914   jt - will check those wires tomorrow. Thanks for t...   Oct 10 2010, 08:23 PM
swl   Could the ignition switch be faulty? That's...   Oct 12 2010, 02:46 PM
poorsche914   Could the ignition switch be faulty? That's ...   Oct 12 2010, 03:00 PM
Spoke   How do you know the engine isn't locked up? I...   Oct 8 2010, 07:28 PM
poorsche914   How do you know the engine isn't locked up?I p...   Oct 8 2010, 08:26 PM
poorsche914   Pulled the starter this morning and applied the BF...   Oct 9 2010, 09:52 AM
hot_shoe914   Pulled the starter this morning and applied the B...   Oct 9 2010, 10:57 AM
Spoke   :headbanger: Good show! This is the opposit...   Oct 10 2010, 05:16 AM
poorsche914   Main goal of getting the engine started has been r...   Oct 10 2010, 11:44 AM
hot_shoe914   Main goal of getting the engine started has been ...   Oct 10 2010, 12:06 PM
JRust   Are the gages connected? Have you had them out sin...   Oct 10 2010, 12:09 PM
poorsche914   Yeah, did the obvious of checking fuses, grounds, ...   Oct 10 2010, 12:21 PM
hot_shoe914   I know why you can't get it fixed. Because you...   Oct 10 2010, 01:03 PM
poorsche914   I currently have no way to do electrical tests. Wi...   Oct 10 2010, 01:12 PM
hot_shoe914   I currently have no way to do electrical tests. W...   Oct 10 2010, 01:29 PM
jt914-6   Check all the large guage wires, four, that connec...   Oct 10 2010, 08:01 PM
ClayPerrine   Bring it to MUSR and I will take a look at it for ...   Oct 11 2010, 11:07 AM
poorsche914   Bring it to MUSR and I will take a look at it for...   Oct 11 2010, 11:28 AM
poorsche914   Long story short, I had swapped out the fuel pump ...   Oct 12 2010, 09:32 AM
type47   Just a guess, but your turn signal/emergency flash...   Oct 12 2010, 09:47 AM
poorsche914   Just a guess, but your turn signal/emergency flas...   Oct 12 2010, 09:50 AM
jt914-6   Trailer it down if you can....as Clay said...there...   Oct 12 2010, 09:55 AM
poorsche914   Trailer it down if you can....as Clay said...ther...   Oct 12 2010, 10:09 AM
jt914-6   How far away are you from Knoxville/Vonore???   Oct 12 2010, 10:27 AM
poorsche914   How far away are you from Knoxville/Vonore??? Ab...   Oct 12 2010, 10:30 AM
poorsche914   Started swapping out relays on the board to see wh...   Oct 12 2010, 02:41 PM
jt914-6   PM Shoe....I think he has both switch and fuel pum...   Oct 12 2010, 03:06 PM
poorsche914   PM Shoe....I think he has both switch and fuel pu...   Oct 12 2010, 03:09 PM
robby750   You are so close to Vonore that it would be worth ...   Oct 12 2010, 03:11 PM
poorsche914   You are so close to Vonore that it would be worth...   Oct 12 2010, 03:15 PM
poorsche914   Well... I swapped out fuel pumps again <_< ...   Oct 13 2010, 10:57 AM
hot_shoe914   Well... I swapped out fuel pumps again <_...   Oct 13 2010, 05:19 PM
poorsche914   Does this mean you are driving it to the ramble? I...   Oct 13 2010, 05:40 PM
Spoke   Right front caliper is sticking pretty bad. :( ...   Oct 13 2010, 05:47 PM
poorsche914   The right front caliper was sticking on my 914. I ...   Oct 13 2010, 06:33 PM
poorsche914   Update: Used some PBlaster on the front caliper ...   Oct 22 2010, 12:09 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 06:28 PM
