poorsche914 |
T4 Supercharged ![]() ![]() ![]() ![]() Group: Members Posts: 3,130 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States ![]() |
I finally decided to tackle getting my LE started and thought the long Labor Day weekend would be the perfect time. I had already replaced the fuel tank and lines up front and had sourced '74 FI parts and bought a new Optima battery. The final piece to the puzzle was a working fuel pump which I got a couple weeks ago.
So this weekend I installed the pump and put power to it. It ran but wasn't pumping fuel up to the engine. I heard gurgling from the tank. Low fuel level. So I added more gas and tried again. Success! Fuel was now being pumped to the fuel rail but there were several leaks. Took care of these and cranked it. Nothing. Pulled two injectors and saw they were not firing. Swapped out harnesses and more of the same. (IMG:style_emoticons/default/sad.gif) I have both a single progressive and dual 40s. I seriously contemplated pulling the FI and installing the single Weber after a rebuild just to get the car running. After chatting with mipstein I had a few things I thought I should try first. I put power to each injector and they all fired so that took bad injectors out of the equation. I looked over pbanders d-jet page for clues. Somewhere along the way I realized the ECU was not getting power and perhaps the relay board was suspect. Having two extra boards, I picked one, transferred relays, etc and plugged it into the 914's harnesses. Turned the key, let fuel pressure build, cranked it and she fired right up!!! (IMG:style_emoticons/default/mueba.gif) Vacuum lines, etc aren't hooked up so it revved high before I turned it off. Next step is to hook up all the vac lines (and install new shift bushings, install accel pedal, etc, etc) Goal is to have it on the road for MUSR11 (IMG:style_emoticons/default/driving.gif) |
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,806 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
I finally decided to tackle getting my LE started and thought the long Labor Day weekend would be the perfect time. I had already replaced the fuel tank and lines up front and had sourced '74 FI parts and bought a new Optima battery. The final piece to the puzzle was a working fuel pump which I got a couple weeks ago. So this weekend I installed the pump and put power to it. It ran but wasn't pumping fuel up to the engine. I heard gurgling from the tank. Low fuel level. So I added more gas and tried again. Success! Fuel was now being pumped to the fuel rail but there were several leaks. Took care of these and cranked it. Nothing. Pulled two injectors and saw they were not firing. Swapped out harnesses and more of the same. (IMG:style_emoticons/default/sad.gif) I have both a single progressive and dual 40s. I seriously contemplated pulling the FI and installing the single Weber after a rebuild just to get the car running. After chatting with mipstein I had a few things I thought I should try first. I put power to each injector and they all fired so that took bad injectors out of the equation. I looked over pbanders d-jet page for clues. Somewhere along the way I realized the ECU was not getting power and perhaps the relay board was suspect. Having two extra boards, I picked one, transferred relays, etc and plugged it into the 914's harnesses. Turned the key, let fuel pressure build, cranked it and she fired right up!!! (IMG:style_emoticons/default/mueba.gif) Vacuum lines, etc aren't hooked up so it revved high before I turned it off. Next step is to hook up all the vac lines (and install new shift bushings, install accel pedal, etc, etc) Goal is to have it on the road for MUSR11 (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
poorsche914 |
Got a vacuum line kit from AA and installed it last night. Hooked everything up according to the schematic which was very helpful.
Turned the key and it would turn over but not fire. (IMG:style_emoticons/default/dry.gif) Pump runs for several seconds and then turns off so apparently system is getting pressurized. Today I tried some starting fluid to see if that would help. Nothing. Unhooked the advance and plugged the nipple on the throttle body. Pulled a plug wire and inserted a spare plug to check for fire. Had my son turn the key. It fired right up (IMG:style_emoticons/default/blink.gif) Since I was holding a plug wire, I told him to turn it off. Ran about 5 seconds or so. Replaced plug wire and tried to start it. Started to fire and then BOOOOOM and a cloud of white smoke out the tail pipe. Now, it won't crank. The starter just clicks. (IMG:style_emoticons/default/confused24.gif) Any ideas? Not sure how the BOOM would be related to the starter not working. The motor is not locked up. |
dvtorr |
Newbie ![]() Group: Members Posts: 16 Joined: 5-September 10 From: Colorado Member No.: 12,138 Region Association: None ![]() |
Got a vacuum line kit from AA and installed it last night. Hooked everything up according to the schematic which was very helpful. Turned the key and it would turn over but not fire. (IMG:style_emoticons/default/dry.gif) Pump runs for several seconds and then turns off so apparently system is getting pressurized. Today I tried some starting fluid to see if that would help. Nothing. Unhooked the advance and plugged the nipple on the throttle body. Pulled a plug wire and inserted a spare plug to check for fire. Had my son turn the key. It fired right up (IMG:style_emoticons/default/blink.gif) Since I was holding a plug wire, I told him to turn it off. Ran about 5 seconds or so. Replaced plug wire and tried to start it. Started to fire and then BOOOOOM and a cloud of white smoke out the tail pipe. Now, it won't crank. The starter just clicks. (IMG:style_emoticons/default/confused24.gif) Any ideas? Not sure how the BOOM would be related to the starter not working. The motor is not locked up. is it a click or more like a clunk sounds? Same thing happened to me and Idk if my motor is seized up or not. Right now Im stuck on this.. Figuring out the problem isnt easy! what is a BFH treatment for the starter? |
poorsche914 |
is it a click or more like a clunk sounds? Same thing happened to me and Idk if my motor is seized up or not. Right now Im stuck on this.. Figuring out the problem isnt easy! what is a BFH treatment for the starter? For me, it was a click at the starter. I removed the starter and gave it the BFH treatment which is banging on it with a hammer. Whatever was stuck came unstuck and it has been working ever since. (IMG:style_emoticons/default/confused24.gif) As far as my electrical issue - hooked up the center console gauges and none of them work. Well, except for the clock (IMG:style_emoticons/default/blink.gif) Any idea what one main thing might be keeping all the gauges and blinkers and dash lights from working? As an added note, the hazard lights work but does not show on the indicator on the tach. |
hot_shoe914 |
is it a click or more like a clunk sounds? Same thing happened to me and Idk if my motor is seized up or not. Right now Im stuck on this.. Figuring out the problem isnt easy! what is a BFH treatment for the starter? For me, it was a click at the starter. I removed the starter and gave it the BFH treatment which is banging on it with a hammer. Whatever was stuck came unstuck and it has been working ever since. (IMG:style_emoticons/default/confused24.gif) As far as my electrical issue - hooked up the center console gauges and none of them work. Well, except for the clock (IMG:style_emoticons/default/blink.gif) Any idea what one main thing might be keeping all the gauges and blinkers and dash lights from working? As an added note, the hazard lights work but does not show on the indicator on the tach. Back up a step. You said you swapped out the relay board. Did the gauges and such work before or after you swapped board? |
poorsche914 |
Back up a step. You said you swapped out the relay board. Did the gauges and such work before or after you swapped board? For whatever reason, the fuel pump is connected to the (+) on the coil. Also, the tach wire and a couple others (a blue and a brown w/white stripe) from the main harness to the relay board are cut. Don't know why the wires were cut. I have taped them back together. Looks like I need to invest in some testing equipment (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 3rd April 2025 - 06:28 PM |
