steveherman |
Member ![]() ![]() Group: Members Posts: 380 Joined: 12-September 09 From: Kissimmee Florida Member No.: 10,799 Region Association: South East States ![]() |
Working on a 1974 2.0 d-jet
-symptom 1- when i start it... idle is very low no where near the 1600 rpm as Brad mentions -symptom 2- low idle...like 550 rpm -symptom 3- when coming to a stop it almost dies -symptom 4- stomp on gas when sitting and driving it goes blah... then takes off. -symptom 5- as it warms up loses a little power things to note: -there are 20 clicks when pushing down accelerator so tps is correct -timing and dwell were checked today and they were within spec. -lifters just adjusted |
steveherman |
ook so i also added another symptom.
i think this may be the culprit to all the other problems. if i find and fix when starting it... idle is very low no where near the 1600 rpm as Brad mentions |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
... idle is very low no where near the 1600 rpm as Brad mentions A - Brad who ? B - 1600 rpm is _not_ normal idle !! Any street Porsche should idle at not more than 1000 rpm. 850 +- a few would be a nice goal, IMO, and 600 is not too low unless there's a lot of miles and low oil pressure and/or cooling is a big factor. Where exactly did you see the reference that a T-IV should idle at 1600 ? |
Lo-Fi Version | Time is now: 25th June 2024 - 10:22 PM |
