SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Just a friendly note .... The famous Perry Kiehl Umbrella Cover is available again. He has 5 left in stock for anyone looking.
If you haven't seen one of the these, they are outstanding quality and FIT. I have no stake in this, but this is the second one I have bought from him. |
realred914 |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None ![]() |
id be concerned that a water proof cover would trap moisture and that would damage the paint. . I made the mistake of a water proof cover once and sure enough, ruined paint. I'd consider one in a breathable material. one good material from a breathability standpoint is Tyvek. I have car covers of this material and it is good for long term outside storage.
for short term use it is ok to be water proof, but long term it can cuase probelms on the paint and other surfaces |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,733 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
id be concerned that a water proof cover would trap moisture and that would damage the paint. . I made the mistake of a water proof cover once and sure enough, ruined paint. I'd consider one in a breathable material. one good material from a breathability standpoint is Tyvek. I have car covers of this material and it is good for long term outside storage. for short term use it is ok to be water proof, but long term it can cuase probelms on the paint and other surfaces My cover doesn't really cover the paint. It's waterproof because that's what you need, where it needs to be waterproof. This cover won't give your 914 the "wet T shirt" treatment. Did you look at the pics in this thread? (IMG:style_emoticons/default/confused24.gif) |
realred914 |
id be concerned that a water proof cover would trap moisture and that would damage the paint. . I made the mistake of a water proof cover once and sure enough, ruined paint. I'd consider one in a breathable material. one good material from a breathability standpoint is Tyvek. I have car covers of this material and it is good for long term outside storage. for short term use it is ok to be water proof, but long term it can cuase probelms on the paint and other surfaces My cover doesn't really cover the paint. It's waterproof because that's what you need, where it needs to be waterproof. This cover won't give your 914 the "wet T shirt" treatment. Did you look at the pics in this thread? (IMG:style_emoticons/default/confused24.gif) yes I looked at the photos, nice product, but it does cover paint, not all paint but some (window frame paint and sail panel (may or may not be painted)) it is likely just fine for short term wet use, but my experince with water proof plastic on teh car is that it can allow moisture to build up and cause paint failure (in my case it was a plastic tarp over the top of the car to prevent targa top leaks, it was all held down my a breathable car cover, had lots of moisture probelms under the plastic tarp. that is my experince with a non-breathable cover. That is why I suggested tyvek or some breathable material. the top you have is a very nice idea, just got to be careful with how it is used. if used as a sun shield in the non rainy season i see no probelms, i see a poster advocating its water proofness to help keep water out, it can be a probelm if water does get under it (say it is a installed on a wet car, or wind or humidty allow water under it. but will hurt paint only if left on the car for an extened period of time. some folks may attempt to use this product as a winter storage water proof top seal, and that could cause probelms. if used as a nice sun shield in teh summer , or removed freqeuntly during the rains then there should be no problem, but for long term outdoor winter storage it may cause problems. one shoudl periodically check under it for moisture build up, if it builds up, then it needs to be periodically dried out. nice product though when used as a sun shield. or intermitant use in the rain. for long term wet storage i would be hesitant to use it. Dont get me wrong, i think it is great product for reducing sun damage and keeping the cockpit cooler. |
AndyB |
The Governor is watching me ![]() ![]() ![]() Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States ![]() |
id be concerned that a water proof cover would trap moisture and that would damage the paint. . I made the mistake of a water proof cover once and sure enough, ruined paint. I'd consider one in a breathable material. one good material from a breathability standpoint is Tyvek. I have car covers of this material and it is good for long term outside storage. for short term use it is ok to be water proof, but long term it can cuase probelms on the paint and other surfaces My cover doesn't really cover the paint. It's waterproof because that's what you need, where it needs to be waterproof. This cover won't give your 914 the "wet T shirt" treatment. Did you look at the pics in this thread? (IMG:style_emoticons/default/confused24.gif) yes I looked at the photos, nice product, but it does cover paint, not all paint but some (window frame paint and sail panel (may or may not be painted)) it is likely just fine for short term wet use, but my experince with water proof plastic on teh car is that it can allow moisture to build up and cause paint failure (in my case it was a plastic tarp over the top of the car to prevent targa top leaks, it was all held down my a breathable car cover, had lots of moisture probelms under the plastic tarp. that is my experince with a non-breathable cover. That is why I suggested tyvek or some breathable material. the top you have is a very nice idea, just got to be careful with how it is used. if used as a sun shield in the non rainy season i see no probelms, i see a poster advocating its water proofness to help keep water out, it can be a probelm if water does get under it (say it is a installed on a wet car, or wind or humidty allow water under it. but will hurt paint only if left on the car for an extened period of time. some folks may attempt to use this product as a winter storage water proof top seal, and that could cause probelms. if used as a nice sun shield in teh summer , or removed freqeuntly during the rains then there should be no problem, but for long term outdoor winter storage it may cause problems. one shoudl periodically check under it for moisture build up, if it builds up, then it needs to be periodically dried out. nice product though when used as a sun shield. or intermitant use in the rain. for long term wet storage i would be hesitant to use it. Dont get me wrong, i think it is great product for reducing sun damage and keeping the cockpit cooler. (IMG:style_emoticons/default/dry.gif) Thats all I will say |
Lo-Fi Version | Time is now: 20th June 2024 - 11:18 PM |
