Weber Question, Right & Left? |
GTown74 |
Oct 20 2010, 09:10 PM
Newbie Group: Members Posts: 11 Joined: 14-September 10 From: Garner NC Member No.: 12,174 Region Association: None |
Hi Everyone,
I just got a new set of Dual Weber 40mm and I was told by the company in which I purchased them that Webers do not come in right & left side dual carbs like Dells. Is this correct? Both of the carbs are identical which seems odd to me. This puts one main throttle shaft/speed control screw facing the front of the car and the other facing the back of the car on the other carb. Which in turn only allows me to hook up the linkage bar to the speed control end of one main throttle shaft and the other has to be hooked up to the back side on the other carb. All of the photos of dual Webers I've seen online have both speed control screws always facing the front towards the linkage. Is something a miss here or is this the way Webers are just set-up? Thanks for your help in advance! |
914itis |
Oct 20 2010, 09:16 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Hi Everyone, I just got a new set of Dual Weber 40mm and I was told by the company in which I purchased them that Webers do not come in right & left side dual carbs like Dells. Is this correct? Both of the carbs are identical which seems odd to me. This puts one main throttle shaft/speed control screw facing the front of the car and the other facing the back of the car on the other carb. Which in turn only allows me to hook up the linkage bar to the speed control end of one main throttle shaft and the other has to be hooked up to the back side on the other carb. All of the photos of dual Webers I've seen online have both speed control screws always facing the front towards the linkage. Is something a miss here or is this the way Webers are just set-up? Thanks for your help in advance! I have a set on my car and they are interexhangeable. they are exatly the same. I had to switch them to gat a better adjustment of the accelerator cable. |
Lo-Fi Version | Time is now: 26th December 2024 - 08:57 PM |
