> Weber Question, Right & Left?
GTown74
post Oct 20 2010, 09:10 PM
Hi Everyone,
I just got a new set of Dual Weber 40mm and I was told by the company in which I purchased them that Webers do not come in right & left side dual carbs like Dells. Is this correct?
Both of the carbs are identical which seems odd to me. This puts one main throttle shaft/speed control screw facing the front of the car and the other facing the back of the car on the other carb. Which in turn only allows me to hook up the linkage bar to the speed control end of one main throttle shaft and the other has to be hooked up to the back side on the other carb.
All of the photos of dual Webers I've seen online have both speed control screws always facing the front towards the linkage. Is something a miss here or is this the way Webers are just set-up?
Thanks for your help in advance!
john rogers
post Oct 20 2010, 10:19 PM
The guy was right, there is no right or left Weber as they were probably made for setting inline like the middle of a Ferrari V12 or similar. The attachments on the end of the throttle shafts are swappable to either side of the carb so when you put them onto the manifolds you can see which side the crossbar linkage fits better. If you do that, don't bolt them down solid in case you need to pull them to do some swapping and if you pull the carbs be sure to PLUG the intake ports so nothing falls down inside.
post Oct 20 2010, 11:38 PM
Resident German
QUOTE(john rogers @ Oct 20 2010, 09:19 PM) *
- Lo-Fi Version Time is now: 26th December 2024 - 09:44 PM
