Type 1 CV Joints, Using Type 1 CV Joints |
LotusJoe |
Oct 26 2010, 03:46 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
Has anyone used type one CV joints? They are dimensionally the same. The type one joint does not use the gasket like the original joint. Also all the holes are the same size and will not accommodate the 10 mm roll pin.
I made some pins that fit the stub axle and transmission flange while fitting the hole in the type 1 CV joint. That way no modification is required to either component. I used 1211 sealant in place of the gasket. Anyone else done this? |
Cap'n Krusty |
Oct 26 2010, 04:48 PM
Eric Shea makes/sells 914 modded T1 CV joints. (PMB Performance).
Lo-Fi Version | Time is now: 27th December 2024 - 10:20 AM |
