Type 1 CV Joints, Using Type 1 CV Joints |
LotusJoe |
Oct 26 2010, 03:46 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
Has anyone used type one CV joints? They are dimensionally the same. The type one joint does not use the gasket like the original joint. Also all the holes are the same size and will not accommodate the 10 mm roll pin.
I made some pins that fit the stub axle and transmission flange while fitting the hole in the type 1 CV joint. That way no modification is required to either component. I used 1211 sealant in place of the gasket. Anyone else done this? |
Rotary'14 |
Oct 26 2010, 09:59 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Hi Joe,, I like your simple fix.
Are your roll pins aluminum? because they look like it in the pic. If you make them out of steel, you should offer those for sale. I know I want 2 sets. (IMG:style_emoticons/default/biggrin.gif) -Robert |
Lo-Fi Version | Time is now: 27th December 2024 - 10:53 AM |
