> Type 1 CV Joints, Using Type 1 CV Joints
LotusJoe
post Oct 26 2010, 03:46 PM
Europa Twink Driver
Has anyone used type one CV joints? They are dimensionally the same. The type one joint does not use the gasket like the original joint. Also all the holes are the same size and will not accommodate the 10 mm roll pin.
I made some pins that fit the stub axle and transmission flange while fitting the hole in the type 1 CV joint. That way no modification is required to either component.
I used 1211 sealant in place of the gasket.
Anyone else done this?
Elliot Cannon
post Oct 26 2010, 07:31 PM
Group: Retired Members
Are these CV's better? Stronger? Cheaper? What, if any is the advantage?
Cheers, Elliot
Rotary'14
post Oct 26 2010, 10:08 PM
QUOTE(Elliot Cannon @ Oct 26 2010, 06:31 PM) *
Cheers, Elliot
Type 1 CVs are really easy to find and can be found for low cost. The only draw back is their maximum working angle is only 17 degrees compared to 22 degrees in our original 914 CV. This is due to the smaller balls and cage in the T1 CV. Empi (yeah I know they don't have the best reputation) makes an "off road race Type 2 CV" that has a working angle of 25 degrees and has a chromoly ball cage and bigger balls, they take more torque. You know bigger balls is better. (IMG:style_emoticons/default/biggrin.gif) I've read good things about the empi race CV on some other forums when I was doing some research. And T2 CVs will interchange with T1 CVs. Some good info below,,
http://www.blindchickenracing.com/How_to/C..._joints_101.htm
-Robert
LotusJoe   Type 1 CV Joints   Oct 26 2010, 03:46 PM
kg6dxn   I run 930 CV's but only because I was tired of...   Oct 26 2010, 04:42 PM
Cap'n Krusty   Eric Shea makes/sells 914 modded T1 CV joints. (P...   Oct 26 2010, 04:48 PM
Racer Chris   Eric Shea makes/sells 914 modded T1 CV joints. (...   Oct 26 2010, 05:03 PM
Elliot Cannon   Are these CV's better? Stronger? Cheaper? W...   Oct 26 2010, 07:31 PM
Vacca Rabite   Are these CV's better? Stronger? Cheaper? ...   Oct 26 2010, 08:02 PM
Rotary'14   Are these CV's better? Stronger? Cheaper? ...   Oct 26 2010, 10:08 PM
LotusJoe   Are these CV's better? Stronger? Cheaper? ...   Oct 27 2010, 07:08 PM
Rotary'14   [quote name='Rotary'14' post='1387322' date='...   Oct 27 2010, 11:17 PM
LotusJoe   Even though our engines are type 4,, I NEVER said...   Oct 28 2010, 05:13 PM
Rotary'14   Hi Joe,, I like your simple fix. Are your roll pi...   Oct 26 2010, 09:59 PM
LotusJoe   Hi Joe,, I like your simple fix. Are your roll p...   Oct 27 2010, 06:46 PM
john rogers   I used Eric's CV joints on my vintage race car...   Oct 26 2010, 10:03 PM
charliew   Those pins look like steel to me. I'm sure the...   Oct 26 2010, 10:07 PM
Eric_Shea   They are now... :D   Oct 26 2010, 11:24 PM
Eric_Shea   No... I do believe Robert is wrong. McMark has ...   Oct 27 2010, 08:35 PM
plays with cars   Great information. Always good to find alternate ...   Oct 27 2010, 11:11 PM
pcar916   Does anyone know how original -6 CVs factor in? ...   Oct 28 2010, 08:09 AM
john rogers   I thought this had been beat completely before but...   Oct 27 2010, 11:36 PM
Eric_Shea   Same dimensionally... just a different axle and ...   Oct 28 2010, 07:51 AM
pcar916   How long have most peoples 914 CV's lasted? ...   Oct 28 2010, 08:11 AM
rick 918-S   Then there are conversion cars like mine that have...   Oct 28 2010, 08:13 AM
pcar916   I think I may need to look at 930 joints in the f...   Oct 28 2010, 08:30 AM
Eric_Shea   And possibly some custom length axles.   Oct 28 2010, 03:38 PM
underthetire   Just FYI, stainless is pretty soft, not very britt...   Oct 28 2010, 04:50 PM
- Lo-Fi Version Time is now: 27th December 2024 - 10:43 AM
