Full flow oil system, is this bs or what? |
kdfoust |
Mar 21 2004, 03:47 AM
Senior Member Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
I'll be getting my case back from RIMCO pretty soon and I'm thinking about the oil system. I'm planning to run a 30mm Schradeck (sp?) pump. I've read a number of threads about "full flow" oiling for TIV engines and I guess I don't get it.
For full flow on a TIV you do what? Plug or modify the oil filter bypass valve that I've circled below? Then what? Modify the oil pressure relief valve (new spring I guess) to accomodate higher pressure? Then what? At what pressure does the stock cooler blow open like a pan of Pop-Magic pop corn? TIA, Kevin Attached image(s) |
ThinAir |
Mar 24 2004, 09:29 AM
Best friends Group: Members Posts: 2,553 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
QUOTE(Brad Roberts @ Mar 23 2004, 11:34 PM) We run remote filter setups in the 4cyl race cars (the real race engines). I have never seen an issue with a full prepped stock injected race 2.0 engine. So Brad - does this mean it's a non-issue and you shouldn't worry about making this modification or it's a non-issue because clogged oil filters occur so rarely (IMG:style_emoticons/default/huh.gif) I'm confused (IMG:style_emoticons/default/wacko.gif) |
Lo-Fi Version | Time is now: 20th October 2024 - 06:54 AM |
