> suby turbo , the epic, resurrection
d914
post Oct 4 2009, 02:51 PM
been working on my project for awhile now,, read a long time!!!!..latest update..she's not naked any longer...2 years of bare metal and now I started spraying...... First time.. I'm handling the primer on my own.. (IMG:style_emoticons/default/wacko.gif)
Bigkat is traveling for work or some lame excuse!! (IMG:style_emoticons/default/beer.gif)
He will be handling the final hot rod black..
acid etch primer and the gray primer
d914
post Oct 31 2010, 01:29 PM
I took out the engine tray to keep things clean and give some better access.. I could so something like that and use fasteners to drop out of the way for service...uummmm phase 2... I need this thing on the ground and under power for some fun.. its been drug out way to long..
Hontec
post Oct 31 2010, 01:42 PM
I see things.....
Region Association: Europe
QUOTE(d914 @ Oct 31 2010, 09:29 PM) *
the way you built the engine frame, it's easy to make a flat bottom!
Keep up the Nice work!
d914   suby turbo , the epic   Oct 4 2009, 02:51 PM
d914   flares will have welting and be riveted on.. again...   Oct 4 2009, 02:54 PM
d914   seats,,,ultra shield rally   Oct 4 2009, 02:56 PM
d914   trunks, bottom and engine bay undercoated..   Oct 4 2009, 03:02 PM
faux916   Nice project Greg! Are those the wider GT fla...   Oct 4 2009, 03:04 PM
d914   yes normal are 7 and 9,, these are 9 and 12..vario...   Oct 4 2009, 03:16 PM
faux916   yes normal are 7 and 9,, these are 9 and 12..vari...   Oct 4 2009, 03:49 PM
d914   for old time sake...the engine..   Oct 4 2009, 05:47 PM
d914   a little mock up to keep me going..   Oct 4 2009, 07:02 PM
pktzygt   For a while it was looking like you were going to ...   Oct 4 2009, 07:35 PM
ghuff   What is that shifter setup? That looks delightfull...   Oct 4 2009, 07:37 PM
d914   Im using the suby tranny with a honda cable shifte...   Oct 4 2009, 07:39 PM
quadracerx   Excellent job.....Keep up the good work....Im tryi...   Oct 5 2009, 06:02 PM
carr914   I don't think you will find those wider flares...   Oct 5 2009, 06:15 PM
d914   mind are fg...tried to convince the son to go stee...   Oct 5 2009, 06:31 PM
d914   For a while it was looking like you were going to...   Oct 5 2009, 06:35 PM
d914   primed, sanded, bondo'd, trial fit the rockers...   Oct 18 2009, 08:06 PM
d914   ok long time and no update, I finisged body work, ...   Dec 6 2009, 07:58 PM
Gint   That's cool... :trophy:   Dec 6 2009, 08:42 PM
d914   definitly some touch up do,,daylight is not your f...   Dec 7 2009, 10:10 AM
Zardozz   I'm about to throw some FG flares on my car. I...   Dec 7 2009, 10:18 AM
d914   Im not going for a smooth polished finish,, hotrod...   Dec 7 2009, 10:43 AM
d914   went parts hunting in NASCAR country and came up w...   Dec 10 2009, 02:03 PM
BIGKAT_83   Let see some pictures of the ROCK battery. Thats a...   Dec 10 2009, 07:24 PM
d914   Merry christmas to me... I did a little more negoi...   Dec 11 2009, 09:47 AM
d914   finally off the rotiserre(sp)!!!!...   Dec 20 2009, 07:38 PM
d914   got my dash   Feb 28 2010, 10:26 AM
d914   fnally saw some day light and started playing with...   Feb 28 2010, 10:29 AM
d914   Just a little update: Picked up another AL seat a...   May 9 2010, 07:02 PM
d914   Ive been distracted by Went to the Mitty,,, to ...   May 9 2010, 07:06 PM
d914   still buying parts and sanding.....did I mention I...   May 23 2010, 01:12 PM
BIGKAT_83   still buying parts and sanding.....did I mention ...   May 23 2010, 02:01 PM
d914   mercy post!!!! By the way I stil...   May 23 2010, 02:55 PM
charliew   Try thinning the paint more. Usually the paint is ...   May 23 2010, 04:36 PM
d914   ok its been awhile....Test drove Bob's car.......   Sep 14 2010, 05:01 PM
d914   my revolutions.... I have 4 fuchs 8x15 for track.....   Sep 14 2010, 05:05 PM
d914   oh,,, new turbo tie rods, and yes the $10 bik...   Sep 14 2010, 05:14 PM
Britain Smith   Do you have an pictures of your engine cradle? -B...   Oct 25 2010, 10:58 PM
d914   I will this weekend. I have to pull it, sand it am...   Oct 26 2010, 06:28 AM
d914   engine bar done and being sanded and painted ...   Oct 30 2010, 05:13 PM
d914   picked up a set of three piece wheels...16" ...   Oct 30 2010, 05:17 PM
d914   engine in and mocked up two ways.. First intake f...   Oct 31 2010, 12:04 PM
d914   engine bar back in   Oct 31 2010, 12:06 PM
Hontec   Looking real good! Is that an outfront motor...   Oct 31 2010, 12:58 PM
d914   yes, They also have a lot of little stufff, block ...   Oct 31 2010, 01:12 PM
Hontec   yes, They also have a lot of little stufff, block...   Oct 31 2010, 01:23 PM
d914   I took out the engine tray to keep things clean an...   Oct 31 2010, 01:29 PM
Hontec   I took out the engine tray to keep things clean a...   Oct 31 2010, 01:42 PM
pktzygt   Looks good, I just shipped my harness to outfront ...   Oct 31 2010, 06:43 PM
d914   I did the same thing.. Takes all of ten minutes to...   Oct 31 2010, 07:46 PM
arkitect   Greg, Cool build. With your older picts of your r...   Oct 31 2010, 08:06 PM
d914   no problems, but it also didnt have casters on it ...   Oct 31 2010, 08:12 PM
charliew   Greg I was looking at the turbo and thought about ...   Nov 3 2010, 08:40 PM
d914   I got the line from outback,,,its like a dash 3 or...   Nov 4 2010, 09:00 AM
Brett W   Bout time you get something done. I thought this ...   Nov 4 2010, 09:40 AM
d914   your right even I was begining to think it was a m...   Nov 4 2010, 10:50 AM
Zaney   Nice engine cradle! What do you plan for a sh...   Nov 4 2010, 09:52 PM
abayer1969   What hotrod wiring harness did you end up going wi...   Nov 5 2010, 05:31 AM
d914   shifting is going to be a cable shifter, 90's ...   Nov 5 2010, 09:52 AM
abayer1969   shifting is going to be a cable shifter, 90's...   Nov 5 2010, 10:10 AM
d914   Im going to re-paint,,, was going to be this weeke...   Nov 5 2010, 11:33 AM
d914   my experimental hood.. Its a little wavey!...   Nov 6 2010, 07:21 PM
d914   RE: suby turbo , the epic   Nov 6 2010, 07:28 PM
d914   did some painting this weekend.. not perfect but n...   Nov 8 2010, 02:47 PM
kg6dxn   I like the idea of your hood. I'm concerned th...   Nov 8 2010, 08:21 PM
d914   I will, but we have done some checking and over al...   Nov 8 2010, 10:34 PM
d914   painted and putting the flares on!!   Nov 13 2010, 02:25 PM
d914   one side done, came out reasonably well conciderin...   Nov 13 2010, 02:27 PM
d914   Went to bob's (bigkat) and borrowed the soda b...   Nov 14 2010, 07:18 PM
Britain Smith   Why no thermostat? Are you worried it will take f...   Nov 15 2010, 11:53 PM
Andyrew   Greg, its looking great so far! I however ag...   Nov 16 2010, 12:18 AM
d914   Why no thermostat? Are you worried it will take ...   Nov 16 2010, 07:38 AM
d914   ok been awhile but I have been working.. Four year...   Jan 30 2011, 07:10 PM
BIGKAT_83   Looking good lets see some pictures of the gas tan...   Jan 30 2011, 09:07 PM
Britain Smith   Very nice man. -Britain   Jan 31 2011, 12:32 AM
GS Guy   Where did you source the turbo cover? Looks good...   Jan 31 2011, 04:03 PM
d914   stock cover.. Stainless steel.. I just need to mod...   Jan 31 2011, 05:07 PM
kg6dxn   I'm using an air to water intercooler too. I h...   Jan 31 2011, 07:12 PM
d914   there is always a small oil cooler off the engine ...   Jan 31 2011, 08:35 PM
d914   The long EPIC continues.. 6 maybe 7 years into it....   Apr 6 2013, 11:39 AM
d914   Radiator is in and plumbed.. Re-designed the in...   Apr 6 2013, 11:47 AM
d914   Wiring is 70% done... using hot rod Harness and wi...   Apr 6 2013, 11:51 AM
d914   answers from the past... I believe I will be usi...   Apr 6 2013, 11:58 AM
d914   Did I forget to mention BOB!! otherwise kn...   Apr 6 2013, 12:01 PM
d914   shifter in .. We need to reinforce the console som...   Apr 21 2013, 10:03 AM
John Jentz   Looking good, Greg!   Apr 21 2013, 12:48 PM
blitZ   Coming along nicely. What fuel pump did you use?   Apr 22 2013, 11:29 AM
d914   Walpro mounted in the tank using the Suby sept up,...   Apr 22 2013, 01:25 PM
d914   Played with the car a little today. installed Rac...   Aug 4 2013, 03:47 PM
d914   RE: suby turbo , the epic   Aug 4 2013, 04:01 PM
d914   sorry only blurry shots of this..   Aug 4 2013, 04:04 PM
d914   New shocks,, Rebel racing tops, UB Machine bottom....   Oct 6 2013, 12:02 PM
d914   Finally on the ground and headed home for finishi...   Oct 6 2013, 12:06 PM
d914   Still needs to be adjusted.. a bit lop sided.... ...   Oct 6 2013, 12:07 PM
d914   we tried on one of Bob's 17x10's on my car...   Oct 6 2013, 12:09 PM
d914   these will be going on.. 17x9 , 17x8..   Oct 6 2013, 12:13 PM
- Lo-Fi Version Time is now: 19th April 2025 - 03:41 PM
