New Member.. Let the work begin ! |
MrHyde |
Oct 31 2010, 07:16 AM
Senior Member Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
Hi Everyone ! I just picked up my first 914 yesterday ! I've wanted one since I was about 10 and there used to be one ( growing into the ground mind you ) a few houses down from my grandparents.... its a 73' 2.0L .. Its definitely had atleast one body job done to it but it will need some more work... so far, my list is..
pass. door not lined up right but the window is.. I figure its the inner rockers.. weather strips all around... cup sized hole in drivers floor and one in spare tire well.. headlights like to wink up and down (sometimes, not always ) no turn signals.. have to bump start it as turning the key does nothing... breaks.. tranny bangs into each gear... ( might be clutch cable adjustment i hope ) The ignition is the most interesting one... I have started the car up atleast 3 times over a couple days looking at it and talking with the previous owner and it fire up immediately same with other people that went to look at it... Sure enough... Thanks to murphys law, when I go to fire it up and leave... nothing... we put a screw driver over the selenoid terminals and up she went... so I'm thinking it might be the ignition switch.. I just ordered catalogues from Auto Atlanta and need to stop in at Restoration Design in Guelph ( since they're only about 30 min from me ) whenever the last body work was done to it someone put a very liberal ammount of tar-ish stuff over all the metal unerneath so now I cant really tell if theres rust under it ( I'm sure there is )... battery tray has been replaced for sure, but the engine shelf doesnt look too bad.. All in all.. its the best 914 I've looked at for less than $8000 I' ended up paying $3800 for it and drove it home... Now I just have to sell my motorcycle to uphold my end of the deal with my wife .. (IMG:style_emoticons/default/smile.gif) I'm going to get a binder and lots of paper today and start making a list. (IMG:style_emoticons/default/smile.gif) First objective... get the electrical issues sorted, breaks and try adjusting the clutch cable.. if I can get it to pass saftey first, then I can tear into the rest of it.. Thanks for letting me lurk for a while.. Mike I'm try to upload a pic with no luck yet.... |
MrHyde |
Oct 31 2010, 01:17 PM
I've talked to Mike ( Mikes 914s ) prolly 5-8 years ago back when he was in Ajax ( or that area of the GTA).. He's in Colborne now, not port hope.. But I will be haeding there sometime to pick his brain and buy parts n services for sure... Us Mikes have to stick together if we're going to take the world over someday.. (IMG:style_emoticons/default/smile.gif)
I've never done much electrical diagnosis on cars before, so I picked up a multimeter today and I'm going to have a look at it once I get off this computer.. myself , nor the PO had the seatbelt engaged when starting the car so I'm thinking that may have been bypassed at some point. I'm looking for some elecrical diagrams to print out right now.. I'm going to see about visitng the guys at restoration design tomorrow... The rockers are puzzling me right now... The drivers door opens and closes just fine.. Gaps are good. Passanger door sticks a little and has no gap at the top of the door, however the window lines up perfectly with the seal in the B-pillar... So i'm wondering if when a PO did the body work/paint, they fixed the rocker but didnt have it jig'd up right.. Either way, a set of stiffners are in order at the least.. Can those be put on overtop of the inner rockers or does the whole thing have to come out ? Anyways.. I'm going to head out to the garage and tinker on er' Cheers! |
realred914 |
Oct 31 2010, 02:04 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
I've talked to Mike ( Mikes 914s ) prolly 5-8 years ago back when he was in Ajax ( or that area of the GTA).. He's in Colborne now, not port hope.. But I will be haeding there sometime to pick his brain and buy parts n services for sure... Us Mikes have to stick together if we're going to take the world over someday.. (IMG:style_emoticons/default/smile.gif) I've never done much electrical diagnosis on cars before, so I picked up a multimeter today and I'm going to have a look at it once I get off this computer.. myself , nor the PO had the seatbelt engaged when starting the car so I'm thinking that may have been bypassed at some point. I'm looking for some elecrical diagrams to print out right now.. I'm going to see about visitng the guys at restoration design tomorrow... The rockers are puzzling me right now... The drivers door opens and closes just fine.. Gaps are good. Passanger door sticks a little and has no gap at the top of the door, however the window lines up perfectly with the seal in the B-pillar... So i'm wondering if when a PO did the body work/paint, they fixed the rocker but didnt have it jig'd up right.. Either way, a set of stiffners are in order at the least.. Can those be put on overtop of the inner rockers or does the whole thing have to come out ? Anyways.. I'm going to head out to the garage and tinker on er' Cheers! good to see you want to fix it, get teh haynes repair book, it is of great help and shows where a lot of the stuff is and has electric diagrams. not all incluseive but a must have book for 90% of the stuff send some photos of the rust and tar areas so we can help give an assesment of the damage. many folks here have been there done that with rust and can lend some good advice do a general tune up of the wires, clean the ground contacts (there are several thuu out teh car) push on and off the relays clean the contacts, (buy some radio shack contact cleaner, some pipe cleaers and tooth bruch fine scotch brite pads) remove and clean all the fuses (or replace, they corrode) make sure you get the correct values in the right place, the 914 had two varations fo fuse size location, so make sure yours is right for your car. clean teh fuse contacts, and retension the lose clips, do that kind of stuff lectrically, be sure to ohm out the spark plug wires while your at it, be sure to wiggle them when you test. have a fun one,and bye the way welcome to the trials and tribulations of the 914 (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/chowtime.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/santa_smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/type.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/hissyfit.gif) |
Lo-Fi Version | Time is now: 31st October 2024 - 06:17 PM |
