> suby turbo , the epic, resurrection
d914
post Oct 4 2009, 02:51 PM
been working on my project for awhile now,, read a long time!!!!..latest update..she's not naked any longer...2 years of bare metal and now I started spraying...... First time.. I'm handling the primer on my own.. (IMG:style_emoticons/default/wacko.gif)
Bigkat is traveling for work or some lame excuse!! (IMG:style_emoticons/default/beer.gif)
He will be handling the final hot rod black..
acid etch primer and the gray primer
arkitect
post Oct 31 2010, 08:06 PM
Greg,
Cool build. With your older picts of your rotiesere (sp?) you mounted each end flat without attaching the two ends. Did it stay pretty stable, any problems?
Dave
d914   suby turbo , the epic   Oct 4 2009, 02:51 PM
d914   flares will have welting and be riveted on.. again...   Oct 4 2009, 02:54 PM
d914   seats,,,ultra shield rally   Oct 4 2009, 02:56 PM
d914   trunks, bottom and engine bay undercoated..   Oct 4 2009, 03:02 PM
faux916   Nice project Greg! Are those the wider GT fla...   Oct 4 2009, 03:04 PM
d914   yes normal are 7 and 9,, these are 9 and 12..vario...   Oct 4 2009, 03:16 PM
faux916   yes normal are 7 and 9,, these are 9 and 12..vari...   Oct 4 2009, 03:49 PM
d914   for old time sake...the engine..   Oct 4 2009, 05:47 PM
d914   a little mock up to keep me going..   Oct 4 2009, 07:02 PM
pktzygt   For a while it was looking like you were going to ...   Oct 4 2009, 07:35 PM
ghuff   What is that shifter setup? That looks delightfull...   Oct 4 2009, 07:37 PM
d914   Im using the suby tranny with a honda cable shifte...   Oct 4 2009, 07:39 PM
quadracerx   Excellent job.....Keep up the good work....Im tryi...   Oct 5 2009, 06:02 PM
carr914   I don't think you will find those wider flares...   Oct 5 2009, 06:15 PM
d914   mind are fg...tried to convince the son to go stee...   Oct 5 2009, 06:31 PM
d914   For a while it was looking like you were going to...   Oct 5 2009, 06:35 PM
d914   primed, sanded, bondo'd, trial fit the rockers...   Oct 18 2009, 08:06 PM
d914   ok long time and no update, I finisged body work, ...   Dec 6 2009, 07:58 PM
Gint   That's cool... :trophy:   Dec 6 2009, 08:42 PM
d914   definitly some touch up do,,daylight is not your f...   Dec 7 2009, 10:10 AM
Zardozz   I'm about to throw some FG flares on my car. I...   Dec 7 2009, 10:18 AM
d914   Im not going for a smooth polished finish,, hotrod...   Dec 7 2009, 10:43 AM
d914   went parts hunting in NASCAR country and came up w...   Dec 10 2009, 02:03 PM
BIGKAT_83   Let see some pictures of the ROCK battery. Thats a...   Dec 10 2009, 07:24 PM
d914   Merry christmas to me... I did a little more negoi...   Dec 11 2009, 09:47 AM
d914   finally off the rotiserre(sp)!!!!...   Dec 20 2009, 07:38 PM
d914   got my dash   Feb 28 2010, 10:26 AM
d914   fnally saw some day light and started playing with...   Feb 28 2010, 10:29 AM
d914   Just a little update: Picked up another AL seat a...   May 9 2010, 07:02 PM
d914   Ive been distracted by Went to the Mitty,,, to ...   May 9 2010, 07:06 PM
d914   still buying parts and sanding.....did I mention I...   May 23 2010, 01:12 PM
BIGKAT_83   still buying parts and sanding.....did I mention ...   May 23 2010, 02:01 PM
d914   mercy post!!!! By the way I stil...   May 23 2010, 02:55 PM
charliew   Try thinning the paint more. Usually the paint is ...   May 23 2010, 04:36 PM
d914   ok its been awhile....Test drove Bob's car.......   Sep 14 2010, 05:01 PM
d914   my revolutions.... I have 4 fuchs 8x15 for track.....   Sep 14 2010, 05:05 PM
d914   oh,,, new turbo tie rods, and yes the $10 bik...   Sep 14 2010, 05:14 PM
Britain Smith   Do you have an pictures of your engine cradle? -B...   Oct 25 2010, 10:58 PM
d914   I will this weekend. I have to pull it, sand it am...   Oct 26 2010, 06:28 AM
d914   engine bar done and being sanded and painted ...   Oct 30 2010, 05:13 PM
d914   picked up a set of three piece wheels...16" ...   Oct 30 2010, 05:17 PM
d914   engine in and mocked up two ways.. First intake f...   Oct 31 2010, 12:04 PM
d914   engine bar back in   Oct 31 2010, 12:06 PM
Hontec   Looking real good! Is that an outfront motor...   Oct 31 2010, 12:58 PM
d914   yes, They also have a lot of little stufff, block ...   Oct 31 2010, 01:12 PM
Hontec   yes, They also have a lot of little stufff, block...   Oct 31 2010, 01:23 PM
d914   I took out the engine tray to keep things clean an...   Oct 31 2010, 01:29 PM
Hontec   I took out the engine tray to keep things clean a...   Oct 31 2010, 01:42 PM
pktzygt   Looks good, I just shipped my harness to outfront ...   Oct 31 2010, 06:43 PM
d914   I did the same thing.. Takes all of ten minutes to...   Oct 31 2010, 07:46 PM
arkitect   Greg, Cool build. With your older picts of your r...   Oct 31 2010, 08:06 PM
d914   no problems, but it also didnt have casters on it ...   Oct 31 2010, 08:12 PM
charliew   Greg I was looking at the turbo and thought about ...   Nov 3 2010, 08:40 PM
d914   I got the line from outback,,,its like a dash 3 or...   Nov 4 2010, 09:00 AM
Brett W   Bout time you get something done. I thought this ...   Nov 4 2010, 09:40 AM
d914   your right even I was begining to think it was a m...   Nov 4 2010, 10:50 AM
Zaney   Nice engine cradle! What do you plan for a sh...   Nov 4 2010, 09:52 PM
abayer1969   What hotrod wiring harness did you end up going wi...   Nov 5 2010, 05:31 AM
d914   shifting is going to be a cable shifter, 90's ...   Nov 5 2010, 09:52 AM
abayer1969   shifting is going to be a cable shifter, 90's...   Nov 5 2010, 10:10 AM
d914   Im going to re-paint,,, was going to be this weeke...   Nov 5 2010, 11:33 AM
d914   my experimental hood.. Its a little wavey!...   Nov 6 2010, 07:21 PM
d914   RE: suby turbo , the epic   Nov 6 2010, 07:28 PM
d914   did some painting this weekend.. not perfect but n...   Nov 8 2010, 02:47 PM
kg6dxn   I like the idea of your hood. I'm concerned th...   Nov 8 2010, 08:21 PM
d914   I will, but we have done some checking and over al...   Nov 8 2010, 10:34 PM
d914   painted and putting the flares on!!   Nov 13 2010, 02:25 PM
d914   one side done, came out reasonably well conciderin...   Nov 13 2010, 02:27 PM
d914   Went to bob's (bigkat) and borrowed the soda b...   Nov 14 2010, 07:18 PM
Britain Smith   Why no thermostat? Are you worried it will take f...   Nov 15 2010, 11:53 PM
Andyrew   Greg, its looking great so far! I however ag...   Nov 16 2010, 12:18 AM
d914   Why no thermostat? Are you worried it will take ...   Nov 16 2010, 07:38 AM
d914   ok been awhile but I have been working.. Four year...   Jan 30 2011, 07:10 PM
BIGKAT_83   Looking good lets see some pictures of the gas tan...   Jan 30 2011, 09:07 PM
Britain Smith   Very nice man. -Britain   Jan 31 2011, 12:32 AM
GS Guy   Where did you source the turbo cover? Looks good...   Jan 31 2011, 04:03 PM
d914   stock cover.. Stainless steel.. I just need to mod...   Jan 31 2011, 05:07 PM
kg6dxn   I'm using an air to water intercooler too. I h...   Jan 31 2011, 07:12 PM
d914   there is always a small oil cooler off the engine ...   Jan 31 2011, 08:35 PM
d914   The long EPIC continues.. 6 maybe 7 years into it....   Apr 6 2013, 11:39 AM
d914   Radiator is in and plumbed.. Re-designed the in...   Apr 6 2013, 11:47 AM
d914   Wiring is 70% done... using hot rod Harness and wi...   Apr 6 2013, 11:51 AM
d914   answers from the past... I believe I will be usi...   Apr 6 2013, 11:58 AM
d914   Did I forget to mention BOB!! otherwise kn...   Apr 6 2013, 12:01 PM
d914   shifter in .. We need to reinforce the console som...   Apr 21 2013, 10:03 AM
John Jentz   Looking good, Greg!   Apr 21 2013, 12:48 PM
blitZ   Coming along nicely. What fuel pump did you use?   Apr 22 2013, 11:29 AM
d914   Walpro mounted in the tank using the Suby sept up,...   Apr 22 2013, 01:25 PM
d914   Played with the car a little today. installed Rac...   Aug 4 2013, 03:47 PM
d914   RE: suby turbo , the epic   Aug 4 2013, 04:01 PM
d914   sorry only blurry shots of this..   Aug 4 2013, 04:04 PM
d914   New shocks,, Rebel racing tops, UB Machine bottom....   Oct 6 2013, 12:02 PM
d914   Finally on the ground and headed home for finishi...   Oct 6 2013, 12:06 PM
d914   Still needs to be adjusted.. a bit lop sided.... ...   Oct 6 2013, 12:07 PM
d914   we tried on one of Bob's 17x10's on my car...   Oct 6 2013, 12:09 PM
d914   these will be going on.. 17x9 , 17x8..   Oct 6 2013, 12:13 PM
- Lo-Fi Version Time is now: 19th April 2025 - 03:43 PM
