Oil leak behind flywheel I can't find |
tracer |
Oct 24 2010, 03:01 PM
Newbie Group: Members Posts: 44 Joined: 26-July 04 From: El Dorado Hills, CA Member No.: 2,405 Region Association: Northern California |
Hi all, have an oil leak that I have been trying to fix for over a month and 4 main seals. Symptom is oil coming from hole between transmission and case. My first thought were that I needed to replace the main crank seal, well long story, when this thing is leaking it seems you need to to drive at freeway speed for a little while and when you stop and look under the car the entire passenger side has oil slung on the roof and all over the trans and muffler, but only on the passenger side. Today removed the transmission and the inside cavity is covered with oil, this is engine oil and not gear oil. Removed the flywheel and seal looked dry?? Have been cleaning and scanning for anyplace oil could come from. Seems like the drivers side case shell is moist with oil and passenger side is dry. This should be an easy fix but I can't think of another place to check. Could I have a micro crack and oil leaking out under pressure from an oil galley? The oil galley plug on drivers side has been epoxied in and the passenger side has been tapped and plugged. Help!!!
Jake Raby |
Oct 31 2010, 02:52 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Sounds like a leaky galley plug or cam plug.. What oil are you using?
tracer |
Oct 31 2010, 09:42 PM
realred914 |
Nov 1 2010, 08:29 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
Sounds like a leaky galley plug or cam plug.. What oil are you using? 10/30w Castrol GTX kind of thin oil unless you live where it is very cold. moderate temps i use 20w-50. San fransisco bay area weather. do you have an oil pressure gage if so, whats it read for pressure fully warmed up at a given rpm? |
Lo-Fi Version | Time is now: 28th June 2024 - 02:36 PM |
