> Good news..., bad news :-(
poorsche914
post Nov 1 2010, 11:46 AM
T4 Supercharged
Well, I got my LE to start up once again. Ended up being fouled plugs. Replaced with new ones and it fired right up and ran great. Revved up no problems. (IMG:style_emoticons/default/piratenanner.gif)
Lot of white smoke coming out of the exhaust. I thought it might be unburnt fuel until I saw this:
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1288633589.1.jpg)
(IMG:style_emoticons/default/headbang.gif)
messix
post Nov 1 2010, 03:29 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
did you crank this over and over trying to start it?
this could be that you washed down the cylinders with gas from the injectors when it wouldn't start. that would mix with the oil on the cylinders and get past the ring real easy.
drain the oil and see if it smells like gas. if it does change filetr and refill with oil and try it again. the smoke might clear up.
poorsche914
post Nov 1 2010, 03:37 PM
T4 Supercharged
Yes, I did crank and crank and crank....
Also double checked the vac lines. Didn't have the canister hooked in and just joined the two hoses. May have caused pressure from that set up (IMG:style_emoticons/default/confused24.gif)
Have added the canister and, following a vac line diagram I found on the web, made sure all lines were in the correct spot.
Cleaned off plugs and reinstalled.
Will drain oil and add new. After that... start it and let whatever oil is still in cylinders burn off?
Thanks for the input, messix.
so close to (IMG:style_emoticons/default/driving.gif)
messix
post Nov 1 2010, 03:44 PM
QUOTE(poorsche914 @ Nov 1 2010, 02:37 PM) *
don't drive it or run it any more untill you check for gas in the oil, if you do you will end up replacing all bearings in the motor. gas polluted oil will kill bearings quickly.
poorsche914
post Nov 1 2010, 04:10 PM
T4 Supercharged
QUOTE(messix @ Nov 1 2010, 05:44 PM) *
I have drained the oil. It was the consistency of gasoline! Thanks for that advice. Will put fresh oil and filter on tomorrow.
You need to drain the oil from the exhaust (IMG:style_emoticons/default/biggrin.gif) Seriously
I can't just burn it out? (IMG:style_emoticons/default/blink.gif)
Good advice. Thanks.
Closer and closer to (IMG:style_emoticons/default/driving.gif)
messix
post Nov 1 2010, 04:14 PM
QUOTE(poorsche914 @ Nov 1 2010, 03:10 PM) *
you don't have to drain the exhaust (IMG:style_emoticons/default/slap.gif) it will evaporate and burn out on it's own.
poorsche914   Good news...   Nov 1 2010, 11:46 AM
dflesburg   Wonder what was fouling the plugs... LOL   Nov 1 2010, 11:50 AM
messix   DOH! :stooges:   Nov 1 2010, 11:52 AM
Sleepin   I would say that you have a 99-00 Civic that needs...   Nov 1 2010, 12:16 PM
poorsche914   LOL... yep, cleaned that up right away. So... any...   Nov 1 2010, 12:25 PM
ClayPerrine   Dood..... Yer 914 blew a nasty, oily fart all ove...   Nov 1 2010, 12:24 PM
messix   oil level to high, over pressured crankcase [no ve...   Nov 1 2010, 12:35 PM
underthetire   Ha, the 914 just shit on the ricer ! Nice...   Nov 1 2010, 01:00 PM
76-914   Ha, the 914 just shit on the ricer ! Nice...   Nov 1 2010, 01:11 PM
poorsche914   [quote name='underthetire' post='1389438' date='N...   Nov 1 2010, 02:23 PM
messix   #4 doesn't look to good. that hole is most lik...   Nov 1 2010, 02:40 PM
RobW   Bummer on the engine :barf: Classic picture tho...   Nov 1 2010, 03:05 PM
poorsche914   Bummer on the engine :barf: Classic picture th...   Nov 1 2010, 03:38 PM
messix   did you crank this over and over trying to start i...   Nov 1 2010, 03:29 PM
poorsche914   Yes, I did crank and crank and crank.... Also doub...   Nov 1 2010, 03:37 PM
messix   Yes, I did crank and crank and crank.... Also dou...   Nov 1 2010, 03:44 PM
poorsche914   don't drive it or run it any more untill you c...   Nov 1 2010, 04:10 PM
messix   don't drive it or run it any more untill you ...   Nov 1 2010, 04:14 PM
kg6dxn   You need to drain the oil from the exhaust :D Seri...   Nov 1 2010, 03:57 PM
messix   You need to drain the oil from the exhaust :D Ser...   Nov 1 2010, 04:09 PM
rick 918-S   Cool NARP photo! Just like Herbie!   Nov 1 2010, 04:51 PM
windforfun   Nice fart.   Nov 1 2010, 04:54 PM
poorsche914   Nice fart. Technically, I suppose it was a ...   Nov 1 2010, 04:56 PM
r_towle   First, you cant trust a cold compression test. It ...   Nov 1 2010, 05:56 PM
poorsche914   Thanks, Rich. Been planning to get a warm compres...   Nov 1 2010, 06:00 PM
r_towle   if its close...re-torque the heads and test it aga...   Nov 1 2010, 07:06 PM
Black22   My car did everything you described...white smoke....   Nov 1 2010, 07:48 PM
poorsche914   My car did everything you described...white smoke...   Nov 1 2010, 08:46 PM
hot_shoe914   I say you sell that POS to some dumbass in west Te...   Nov 1 2010, 07:59 PM
poorsche914   I say you sell that POS to some dumbass in west T...   Nov 1 2010, 08:51 PM
Root_Werks   Kinda read through all the posts, even the Shartin...   Nov 2 2010, 10:53 AM
underthetire   If it's been sitting, I would run some mystery...   Nov 2 2010, 10:56 AM
poorsche914   If it's been sitting, I would run some myster...   Nov 2 2010, 11:00 AM
underthetire   Oil,er, both. I ran it in the oil, cleans carbon ...   Nov 2 2010, 11:05 AM
poorsche914   Thanks, Jeff. Heading outside shortly to work on i...   Nov 2 2010, 11:11 AM
poorsche914   Update: oil and filter changed. Mystery oil added....   Nov 2 2010, 12:20 PM
messix   how long did it run with the gassy oil in it?   Nov 2 2010, 12:26 PM
poorsche914   Ran for about a minute. Maybe less.   Nov 2 2010, 12:33 PM
underthetire   Get it warm. Mystery oil works better after a warm...   Nov 2 2010, 12:41 PM
messix   get out and put it under a load. give it a couple...   Nov 2 2010, 01:08 PM
poorsche914   Thanks Jeff and Troy. Will get it tagged tomorro...   Nov 2 2010, 02:02 PM
Dr Evil   Gesundheit!   Nov 2 2010, 04:52 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 06:29 PM
