> Good news..., bad news :-(
poorsche914
post Nov 1 2010, 11:46 AM
T4 Supercharged
Well, I got my LE to start up once again. Ended up being fouled plugs. Replaced with new ones and it fired right up and ran great. Revved up no problems. (IMG:style_emoticons/default/piratenanner.gif)
Lot of white smoke coming out of the exhaust. I thought it might be unburnt fuel until I saw this:
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1288633589.1.jpg)
(IMG:style_emoticons/default/headbang.gif)
underthetire
post Nov 2 2010, 11:05 AM
Oil,er, both. I ran it in the oil, cleans carbon out quick like. I ran it for about 200 miles then changed the oil and filter out. Always start with cheap oil on a motor thats been sitting, cause your gonna want to change it right away again. As far as putting it in the fuel, it does help injectors and clean the valves, but I guess so would injector cleaner.
poorsche914
post Nov 2 2010, 11:11 AM
T4 Supercharged
Thanks, Jeff. Heading outside shortly to work on it.
poorsche914   Good news...   Nov 1 2010, 11:46 AM
dflesburg   Wonder what was fouling the plugs... LOL   Nov 1 2010, 11:50 AM
messix   DOH! :stooges:   Nov 1 2010, 11:52 AM
Sleepin   I would say that you have a 99-00 Civic that needs...   Nov 1 2010, 12:16 PM
poorsche914   LOL... yep, cleaned that up right away. So... any...   Nov 1 2010, 12:25 PM
ClayPerrine   Dood..... Yer 914 blew a nasty, oily fart all ove...   Nov 1 2010, 12:24 PM
messix   oil level to high, over pressured crankcase [no ve...   Nov 1 2010, 12:35 PM
underthetire   Ha, the 914 just shit on the ricer ! Nice...   Nov 1 2010, 01:00 PM
76-914   Ha, the 914 just shit on the ricer ! Nice...   Nov 1 2010, 01:11 PM
poorsche914   [quote name='underthetire' post='1389438' date='N...   Nov 1 2010, 02:23 PM
messix   #4 doesn't look to good. that hole is most lik...   Nov 1 2010, 02:40 PM
RobW   Bummer on the engine :barf: Classic picture tho...   Nov 1 2010, 03:05 PM
poorsche914   Bummer on the engine :barf: Classic picture th...   Nov 1 2010, 03:38 PM
messix   did you crank this over and over trying to start i...   Nov 1 2010, 03:29 PM
poorsche914   Yes, I did crank and crank and crank.... Also doub...   Nov 1 2010, 03:37 PM
messix   Yes, I did crank and crank and crank.... Also dou...   Nov 1 2010, 03:44 PM
poorsche914   don't drive it or run it any more untill you c...   Nov 1 2010, 04:10 PM
messix   don't drive it or run it any more untill you ...   Nov 1 2010, 04:14 PM
kg6dxn   You need to drain the oil from the exhaust :D Seri...   Nov 1 2010, 03:57 PM
messix   You need to drain the oil from the exhaust :D Ser...   Nov 1 2010, 04:09 PM
rick 918-S   Cool NARP photo! Just like Herbie!   Nov 1 2010, 04:51 PM
windforfun   Nice fart.   Nov 1 2010, 04:54 PM
poorsche914   Nice fart. Technically, I suppose it was a ...   Nov 1 2010, 04:56 PM
r_towle   First, you cant trust a cold compression test. It ...   Nov 1 2010, 05:56 PM
poorsche914   Thanks, Rich. Been planning to get a warm compres...   Nov 1 2010, 06:00 PM
r_towle   if its close...re-torque the heads and test it aga...   Nov 1 2010, 07:06 PM
Black22   My car did everything you described...white smoke....   Nov 1 2010, 07:48 PM
poorsche914   My car did everything you described...white smoke...   Nov 1 2010, 08:46 PM
hot_shoe914   I say you sell that POS to some dumbass in west Te...   Nov 1 2010, 07:59 PM
poorsche914   I say you sell that POS to some dumbass in west T...   Nov 1 2010, 08:51 PM
Root_Werks   Kinda read through all the posts, even the Shartin...   Nov 2 2010, 10:53 AM
underthetire   If it's been sitting, I would run some mystery...   Nov 2 2010, 10:56 AM
poorsche914   If it's been sitting, I would run some myster...   Nov 2 2010, 11:00 AM
underthetire   Oil,er, both. I ran it in the oil, cleans carbon ...   Nov 2 2010, 11:05 AM
poorsche914   Thanks, Jeff. Heading outside shortly to work on i...   Nov 2 2010, 11:11 AM
poorsche914   Update: oil and filter changed. Mystery oil added....   Nov 2 2010, 12:20 PM
messix   how long did it run with the gassy oil in it?   Nov 2 2010, 12:26 PM
poorsche914   Ran for about a minute. Maybe less.   Nov 2 2010, 12:33 PM
underthetire   Get it warm. Mystery oil works better after a warm...   Nov 2 2010, 12:41 PM
messix   get out and put it under a load. give it a couple...   Nov 2 2010, 01:08 PM
poorsche914   Thanks Jeff and Troy. Will get it tagged tomorro...   Nov 2 2010, 02:02 PM
Dr Evil   Gesundheit!   Nov 2 2010, 04:52 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 06:32 PM
