| d914 |
Oct 4 2009, 02:51 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,350 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
been working on my project for awhile now,, read a long time!!!!..latest update..she's not naked any longer...2 years of bare metal and now I started spraying...... First time.. I'm handling the primer on my own.. (IMG:style_emoticons/default/wacko.gif)
Bigkat is traveling for work or some lame excuse!! (IMG:style_emoticons/default/beer.gif) He will be handling the final hot rod black.. acid etch primer and the gray primer ![]() ![]() |
| charliew |
Nov 3 2010, 08:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
Greg I was looking at the turbo and thought about the restrictor that goes in the oil line to the turbo. Are you using one? We had to use a smaller one on my sons sti because we used a 12mm oil pump with a external pressure regulator and the oil pressure was higher so we had to change to a smaller restrictor to the turbo line to keep from blowing the seal or pumping oil through the turbo.
d914 suby turbo , the epic Oct 4 2009, 02:51 PM
d914 flares will have welting and be riveted on.. again... Oct 4 2009, 02:54 PM
d914 seats,,,ultra shield rally
Oct 4 2009, 02:56 PM
d914 trunks, bottom and engine bay undercoated..
Oct 4 2009, 03:02 PM
faux916 Nice project Greg! Are those the wider GT fla... Oct 4 2009, 03:04 PM
d914 yes normal are 7 and 9,, these are 9 and 12..vario... Oct 4 2009, 03:16 PM
faux916
yes normal are 7 and 9,, these are 9 and 12..vari... Oct 4 2009, 03:49 PM
d914 for old time sake...the engine..
Oct 4 2009, 05:47 PM
d914 a little mock up to keep me going..
Oct 4 2009, 07:02 PM
pktzygt For a while it was looking like you were going to ... Oct 4 2009, 07:35 PM
ghuff What is that shifter setup? That looks delightfull... Oct 4 2009, 07:37 PM
d914 Im using the suby tranny with a honda cable shifte... Oct 4 2009, 07:39 PM
quadracerx Excellent job.....Keep up the good work....Im tryi... Oct 5 2009, 06:02 PM
carr914 I don't think you will find those wider flares... Oct 5 2009, 06:15 PM
d914 mind are fg...tried to convince the son to go stee... Oct 5 2009, 06:31 PM
d914
For a while it was looking like you were going to... Oct 5 2009, 06:35 PM
d914 primed, sanded, bondo'd, trial fit the rockers... Oct 18 2009, 08:06 PM
d914 ok long time and no update, I finisged body work, ... Dec 6 2009, 07:58 PM
Gint That's cool... :trophy: Dec 6 2009, 08:42 PM
d914 definitly some touch up do,,daylight is not your f... Dec 7 2009, 10:10 AM
Zardozz I'm about to throw some FG flares on my car. I... Dec 7 2009, 10:18 AM
d914 Im not going for a smooth polished finish,, hotrod... Dec 7 2009, 10:43 AM
d914 went parts hunting in NASCAR country and came up w... Dec 10 2009, 02:03 PM
BIGKAT_83 Let see some pictures of the ROCK battery. Thats a... Dec 10 2009, 07:24 PM
d914 Merry christmas to me... I did a little more negoi... Dec 11 2009, 09:47 AM
d914 finally off the rotiserre(sp)!!!!... Dec 20 2009, 07:38 PM
d914 got my dash
Feb 28 2010, 10:26 AM
d914 fnally saw some day light and started playing with... Feb 28 2010, 10:29 AM
d914 Just a little update:
Picked up another AL seat a... May 9 2010, 07:02 PM
d914 Ive been distracted by
Went to the Mitty,,, to ... May 9 2010, 07:06 PM
d914 still buying parts and sanding.....did I mention I... May 23 2010, 01:12 PM
BIGKAT_83
still buying parts and sanding.....did I mention ... May 23 2010, 02:01 PM
d914 mercy post!!!! By the way I stil... May 23 2010, 02:55 PM
charliew Try thinning the paint more. Usually the paint is ... May 23 2010, 04:36 PM
d914 ok its been awhile....Test drove Bob's car....... Sep 14 2010, 05:01 PM
d914 my revolutions.... I have 4 fuchs 8x15 for track..... Sep 14 2010, 05:05 PM
d914 oh,,, new turbo tie rods, and yes the $10 bik... Sep 14 2010, 05:14 PM
Britain Smith Do you have an pictures of your engine cradle?
-B... Oct 25 2010, 10:58 PM
d914 I will this weekend. I have to pull it, sand it am... Oct 26 2010, 06:28 AM
d914 engine bar done and being sanded and painted
... Oct 30 2010, 05:13 PM
d914 picked up a set of three piece wheels...16" ... Oct 30 2010, 05:17 PM
d914 engine in and mocked up two ways..
First intake f... Oct 31 2010, 12:04 PM
d914 engine bar back in
Oct 31 2010, 12:06 PM
Hontec Looking real good!
Is that an outfront motor... Oct 31 2010, 12:58 PM
d914 yes, They also have a lot of little stufff, block ... Oct 31 2010, 01:12 PM
Hontec
yes, They also have a lot of little stufff, block... Oct 31 2010, 01:23 PM
d914 I took out the engine tray to keep things clean an... Oct 31 2010, 01:29 PM
Hontec
I took out the engine tray to keep things clean a... Oct 31 2010, 01:42 PM
pktzygt Looks good, I just shipped my harness to outfront ... Oct 31 2010, 06:43 PM
d914 I did the same thing.. Takes all of ten minutes to... Oct 31 2010, 07:46 PM
arkitect Greg,
Cool build. With your older picts of your r... Oct 31 2010, 08:06 PM
d914 no problems, but it also didnt have casters on it ... Oct 31 2010, 08:12 PM
d914 I got the line from outback,,,its like a dash 3 or... Nov 4 2010, 09:00 AM
Brett W Bout time you get something done. I thought this ... Nov 4 2010, 09:40 AM
d914 your right even I was begining to think it was a m... Nov 4 2010, 10:50 AM
Zaney Nice engine cradle!
What do you plan for a sh... Nov 4 2010, 09:52 PM
abayer1969 What hotrod wiring harness did you end up going wi... Nov 5 2010, 05:31 AM
d914 shifting is going to be a cable shifter, 90's ... Nov 5 2010, 09:52 AM
abayer1969
shifting is going to be a cable shifter, 90's... Nov 5 2010, 10:10 AM
d914 Im going to re-paint,,, was going to be this weeke... Nov 5 2010, 11:33 AM
d914 my experimental hood.. Its a little wavey!... Nov 6 2010, 07:21 PM
d914 RE: suby turbo , the epic Nov 6 2010, 07:28 PM
d914 did some painting this weekend.. not perfect but n... Nov 8 2010, 02:47 PM
kg6dxn I like the idea of your hood. I'm concerned th... Nov 8 2010, 08:21 PM
d914 I will, but we have done some checking and over al... Nov 8 2010, 10:34 PM
d914 painted and putting the flares on!!
Nov 13 2010, 02:25 PM
d914 one side done, came out reasonably well conciderin... Nov 13 2010, 02:27 PM
d914 Went to bob's (bigkat) and borrowed the soda b... Nov 14 2010, 07:18 PM
Britain Smith Why no thermostat? Are you worried it will take f... Nov 15 2010, 11:53 PM
Andyrew Greg, its looking great so far!
I however ag... Nov 16 2010, 12:18 AM
d914
Why no thermostat? Are you worried it will take ... Nov 16 2010, 07:38 AM
d914 ok been awhile but I have been working.. Four year... Jan 30 2011, 07:10 PM
BIGKAT_83 Looking good lets see some pictures of the gas tan... Jan 30 2011, 09:07 PM
Britain Smith Very nice man.
-Britain Jan 31 2011, 12:32 AM
GS Guy Where did you source the turbo cover? Looks good... Jan 31 2011, 04:03 PM
d914 stock cover.. Stainless steel.. I just need to mod... Jan 31 2011, 05:07 PM
kg6dxn I'm using an air to water intercooler too. I h... Jan 31 2011, 07:12 PM
d914 there is always a small oil cooler off the engine ... Jan 31 2011, 08:35 PM
d914 The long EPIC continues.. 6 maybe 7 years into it.... Apr 6 2013, 11:39 AM
d914 Radiator is in and plumbed..
Re-designed the in... Apr 6 2013, 11:47 AM
d914 Wiring is 70% done... using hot rod Harness and wi... Apr 6 2013, 11:51 AM
d914 answers from the past...
I believe I will be usi... Apr 6 2013, 11:58 AM
d914 Did I forget to mention BOB!! otherwise kn... Apr 6 2013, 12:01 PM
d914 shifter in .. We need to reinforce the console som... Apr 21 2013, 10:03 AM
John Jentz Looking good, Greg! Apr 21 2013, 12:48 PM
blitZ Coming along nicely. What fuel pump did you use? Apr 22 2013, 11:29 AM
d914 Walpro mounted in the tank using the Suby sept up,... Apr 22 2013, 01:25 PM
d914 Played with the car a little today.
installed Rac... Aug 4 2013, 03:47 PM
d914 RE: suby turbo , the epic Aug 4 2013, 04:01 PM
d914 sorry only blurry shots of this..
Aug 4 2013, 04:04 PM
d914 New shocks,, Rebel racing tops, UB Machine bottom.... Oct 6 2013, 12:02 PM
d914 Finally on the ground and headed home for finishi... Oct 6 2013, 12:06 PM
d914 Still needs to be adjusted.. a bit lop sided....
... Oct 6 2013, 12:07 PM
d914 we tried on one of Bob's 17x10's on my car... Oct 6 2013, 12:09 PM
d914 these will be going on.. 17x9 , 17x8..
Oct 6 2013, 12:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th December 2025 - 05:18 AM |
