naro914 |
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States ![]() |
So, it's been a zillion years since I've autocrossed with real autocross tires, and obviously technology has changed a bit (used to use the BFG R-1 back in early 90's until they stopped making them - went to G-Force, then built the car to full race using slicks)
We rebuilt our 914 (Huey) to use for street/AX after the wreck at Targa Newfoundland, and we've been just using our old street Continentals on it for the local autocrosses - mainly because we only had one set of wheels. Just got another set of wheels, so I got a set of Hoosier A6's. Problem is, I have no idea what pressures these run at. The race car uses Goodyear slicks at 19 psi cold. Car is about 2050 lbs without me - yes, it's heavy, but we drive it for more street/rally/weekends and has a full cage that added weight. 3.2 liter six cyl Carrera suspension Front Weltmeister sway 21 mm torsion bars (I think) can't remember the springs, but I think 180lb Again, it's not set up for A/X, and honestly the local A/X group is not exceptionally competitive like the West coasters are. I am about 1 sec off FTD with 5 year old Conti ContactSport 2's, so A6's should really help. Sorry for the long winded post. Bottom line: what tire pressures should I start with on Hoosier A6? |
naro914 |
thanks guys,
Hoosiers recommendation chart says to start 1-2 psi below the recommended hot pressure of 30-33 psi. Guess I should go a bit lower. forgot to mention, 16 x 7 and 8's so 225/245 tires. I could actually go 8 & 9, they would fit, but I can't find any at a reasonable price. could use another pair of 16x8 at some point... |
Lo-Fi Version | Time is now: 26th June 2024 - 08:31 AM |
