Trying Out A New Material, Duocel Foamed Aluminum |
McMark |
Dec 1 2010, 02:38 PM
I ordered some of this Duocel stuff. It's sheets of 'foamed' 6101-T6 aluminum. I'm going to form a brick that will slip into the stock oil filler tower and hopefully provide significant oil vapor separation from the crankcase ventilation air. Ideally, by slipping this into the stock tower, I can run the breather tube to a carb or FI intake and not have to stress/dealwith large quantities of oil collecting in the intake or fouling the carbs.
Why not a traditional foam? This stuff won't break down over time. Not cheap though. Each 4" x 4" x 0.5" sheet is $30. (IMG:style_emoticons/default/yikes.gif) Oh and if this works it'll appear Original while being Custom. (IMG:style_emoticons/default/sunglasses.gif) Attached image(s) |
McMark |
Dec 1 2010, 06:12 PM
QUOTE If this foam had bits fall off over time, It's certainly possible, but I'm satisfied that it's improbable. I'll plan on cutting open the first couple oil filters and straining the used oil to see if anything is generated. This is absolutely an experiment. |
Lo-Fi Version | Time is now: 28th September 2024 - 07:17 AM |
