sfrenck |
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region ![]() ![]() |
Just started driving my "project" ('73 2.0L with 74' F.I. setup) up and down the block for my preliminary road test. One thing I noticed, and my 79 yr. old father really noticed, was the gas pedal was very stiff.
I have already replaced the plastic bushings in the pedal cluster with the brass rebuild kit. Tonight, I disconnected the throttle cable from the throttle body and confirmed the cable / pedal was not the issue. It seems that the supplemental spring on the throttle body is the culprit. Is there a different, easier spring that I can install or is a stiff gas pedal just part of the normal Porsche engineering? Or, should I look for a '73 throttle body without the supplemental spring? Thanks - Scott |
1988Hawk |
Newbie ![]() Group: Members Posts: 41 Joined: 17-April 08 From: Chicago Member No.: 8,929 Region Association: None ![]() |
Just started driving my "project" ('73 2.0L with 74' F.I. setup) up and down the block for my preliminary road test. One thing I noticed, and my 79 yr. old father really noticed, was the gas pedal was very stiff. I have already replaced the plastic bushings in the pedal cluster with the brass rebuild kit. Tonight, I disconnected the throttle cable from the throttle body and confirmed the cable / pedal was not the issue. It seems that the supplemental spring on the throttle body is the culprit. Is there a different, easier spring that I can install or is a stiff gas pedal just part of the normal Porsche engineering? Or, should I look for a '73 throttle body without the supplemental spring? Thanks - Scott Make sure that the pedal board is not interfering with the pedal action, move the board as far right as you can. |
sfrenck |
Just started driving my "project" ('73 2.0L with 74' F.I. setup) up and down the block for my preliminary road test. One thing I noticed, and my 79 yr. old father really noticed, was the gas pedal was very stiff. I have already replaced the plastic bushings in the pedal cluster with the brass rebuild kit. Tonight, I disconnected the throttle cable from the throttle body and confirmed the cable / pedal was not the issue. It seems that the supplemental spring on the throttle body is the culprit. Is there a different, easier spring that I can install or is a stiff gas pedal just part of the normal Porsche engineering? Or, should I look for a '73 throttle body without the supplemental spring? Thanks - Scott Make sure that the pedal board is not interfering with the pedal action, move the board as far right as you can. Not the pedal board... either the spring is the problem or the butterfly/axle itself. |
okieflyr |
9fauxteen ![]() ![]() ![]() Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States ![]() |
Just started driving my "project" ('73 2.0L with 74' F.I. setup) up and down the block for my preliminary road test. One thing I noticed, and my 79 yr. old father really noticed, was the gas pedal was very stiff. I have already replaced the plastic bushings in the pedal cluster with the brass rebuild kit. Tonight, I disconnected the throttle cable from the throttle body and confirmed the cable / pedal was not the issue. It seems that the supplemental spring on the throttle body is the culprit. Is there a different, easier spring that I can install or is a stiff gas pedal just part of the normal Porsche engineering? Or, should I look for a '73 throttle body without the supplemental spring? Thanks - Scott Make sure that the pedal board is not interfering with the pedal action, move the board as far right as you can. Not the pedal board... either the spring is the problem or the butterfly/axle itself. I've got a spare 75 1.8 supplemental spring that you can have to use or compare. Is it still stiff without it? If the car has been sitting for a long time, the throttle body butterfly may have some corrosion or buildup on it that is dragging. Kevin |
Lo-Fi Version | Time is now: 25th June 2024 - 11:22 PM |
