sfrenck |
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region ![]() ![]() |
Just started driving my "project" ('73 2.0L with 74' F.I. setup) up and down the block for my preliminary road test. One thing I noticed, and my 79 yr. old father really noticed, was the gas pedal was very stiff.
I have already replaced the plastic bushings in the pedal cluster with the brass rebuild kit. Tonight, I disconnected the throttle cable from the throttle body and confirmed the cable / pedal was not the issue. It seems that the supplemental spring on the throttle body is the culprit. Is there a different, easier spring that I can install or is a stiff gas pedal just part of the normal Porsche engineering? Or, should I look for a '73 throttle body without the supplemental spring? Thanks - Scott |
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
I am in this same boat. I am replacing the cable, and the pedal it self to see if that helps. Not sure why the throttle feels so darn stiff compared to other cars.
Lo-Fi Version | Time is now: 25th June 2024 - 11:29 PM |
