sfrenck |
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region ![]() ![]() |
Just started driving my "project" ('73 2.0L with 74' F.I. setup) up and down the block for my preliminary road test. One thing I noticed, and my 79 yr. old father really noticed, was the gas pedal was very stiff.
I have already replaced the plastic bushings in the pedal cluster with the brass rebuild kit. Tonight, I disconnected the throttle cable from the throttle body and confirmed the cable / pedal was not the issue. It seems that the supplemental spring on the throttle body is the culprit. Is there a different, easier spring that I can install or is a stiff gas pedal just part of the normal Porsche engineering? Or, should I look for a '73 throttle body without the supplemental spring? Thanks - Scott |
okieflyr |
9fauxteen ![]() ![]() ![]() Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States ![]() |
If the the throttle body is lubed and smooth as well as the spring, I'd look back to the throttle pedal linkage. Is it possible that it may be getting into a bind when there is a LOAD on the cable? Can you get someone to apply tension or an independant springload on the cable? Can you vouch for the condition of the cable and it's lube? Ain't much, but it's all I got.....
Lo-Fi Version | Time is now: 25th June 2024 - 11:21 PM |
