sfrenck |
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region ![]() ![]() |
Just started driving my "project" ('73 2.0L with 74' F.I. setup) up and down the block for my preliminary road test. One thing I noticed, and my 79 yr. old father really noticed, was the gas pedal was very stiff.
I have already replaced the plastic bushings in the pedal cluster with the brass rebuild kit. Tonight, I disconnected the throttle cable from the throttle body and confirmed the cable / pedal was not the issue. It seems that the supplemental spring on the throttle body is the culprit. Is there a different, easier spring that I can install or is a stiff gas pedal just part of the normal Porsche engineering? Or, should I look for a '73 throttle body without the supplemental spring? Thanks - Scott |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Just because the cable moves freely when disconnected and testing by feel with your hands doesn't mean the cable is ok. They can (and do) wear on the inside and not be affected unless there is tension (as there is when it's installed) on the cable. I've seen just the very slightest bend in the threaded end of the cable cause serious binding with the cable installed and under tension but not when testing by hand and unconnected.
Lo-Fi Version | Time is now: 25th June 2024 - 11:37 PM |
