sfrenck |
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region ![]() ![]() |
Just started driving my "project" ('73 2.0L with 74' F.I. setup) up and down the block for my preliminary road test. One thing I noticed, and my 79 yr. old father really noticed, was the gas pedal was very stiff.
I have already replaced the plastic bushings in the pedal cluster with the brass rebuild kit. Tonight, I disconnected the throttle cable from the throttle body and confirmed the cable / pedal was not the issue. It seems that the supplemental spring on the throttle body is the culprit. Is there a different, easier spring that I can install or is a stiff gas pedal just part of the normal Porsche engineering? Or, should I look for a '73 throttle body without the supplemental spring? Thanks - Scott |
sfrenck |
Cleaned TB back in car and hooked up. The action is easier now so I guess disassembling and cleaning every nook and cranny of the TB helped.
I'm still going to change the throttle cable and play with the amount of force on the top spring - I want to make sure that when the TB flap is closed, the (2) TB axle arms are 180 degrees apart. That will have to wait until the weekend. Oh, and of course the TPS adjustment is now out since I glued the little rubber stopper back in place. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:21 PM |
