> Official Sasquatch build thread Part 1, Cosmo Rotary Turbo... Then boom...
Mike Bellis
post Nov 20 2010, 02:20 PM
Resident Electrician
Many of you know my car. It was Steve Malmz's car he found in a yard as a roller. It was a former SCCA club racer. Malmz named the car Sasquach. Malmz put a V8 in it and drove it until his priorities changed. It was sold to a guy in Kentucky (unknown name), he regeared the transaxle and drove it little. He sold it to a PCA member in Irvine, CA. That guy used it as a DE car until I purchased it. I installed an EFI system and drove the crap out of it. Recently my clutch went out and I decided it was time for a change. The V8 is going to another member. My engine choice is Top Secret, under wraps until I make my final choices. a Turbo Rotary. I'm taking a twin turbo and converting it to a single large turbo. This mod keeps it simple and increases horsepower. My new license plate will be "914 TT".
The car has 930 suspension and brakes. 930 steel flairs grafted on, a total of 8 flairs were used. Two per corner to make up the radius. There is a roll cage with removable door bars. The cage is tied to the rear suspension but not the front. The bodywork ant paint are 10+ years old and the car is several shades of white. The chassis is super solid. Only minor surface rust has been found. The Original owner/racer installer a stiffening kit and various braces. The suspension console is unusual. Steel plats replace the inboard pivots. 1/8" & 1/4" plate steel reenforcement plates are surrounding the console. A 1" bar ties in the console to the firewall.
Here are the first pics of me stripping paint from the engine bay and the unusual consoles.
RJMII
post Dec 11 2010, 10:20 PM
Jim McIntosh
GT35R Ball bearing Turbo- oil and water cooled
HKS cast iron exhaust manifold
Haltech ECU
HKS Blow off Valve
HKS wastgate
HKS Boost controller
2000cc injectors (x4)
Areomotive fuel regulator
Custom Rails
4" exhaust
Aero Turbine Muffler
Frozen Boost air to water intercooler
So are you switching to single turbo with the ball bearing unit?
kg6dxn   Official Sasquatch build thread Part 1   Nov 20 2010, 02:20 PM
kg6dxn   More   Nov 20 2010, 02:21 PM
campbellcj   Subscribed! I remember that car back when Ste...   Nov 20 2010, 02:30 PM
kg6dxn   Here's a nostalgic pic from when Malmz owned i...   Nov 20 2010, 02:38 PM
RJMII   oooh... 914 TT for a plate. :D I'm hooked!   Nov 20 2010, 03:17 PM
Andyrew   Audi 2.7TT? Subaru TT? You gonna cut the engine s...   Nov 20 2010, 03:27 PM
kg6dxn   Audi 2.7TT? Subaru TT? You gonna cut the engine ...   Nov 20 2010, 03:44 PM
Andyrew   Oh ps.. :Qarl:   Nov 20 2010, 03:27 PM
RJMII   Are they held in with spot welds that can be dr...   Nov 20 2010, 03:31 PM
McMark   Are they held in with spot welds that can be dril...   Nov 20 2010, 03:51 PM
ConeDodger   Cool!   Nov 20 2010, 04:48 PM
JRust   Excellent! Can't wait to see what you do w...   Nov 20 2010, 05:12 PM
strawman   Subscribed! Good luck Mike; let me know if you...   Nov 20 2010, 05:42 PM
kg6dxn   Subscribed! Good luck Mike; let me know if yo...   Nov 20 2010, 05:52 PM
Lennies914   Subscribed as well. I thought you were thinking r...   Nov 20 2010, 07:32 PM
kg6dxn   Subscribed as well. I thought you were thinking ...   Nov 20 2010, 08:48 PM
roadster fan   Hmmm....a 13B-REW Rotary/Wankel motor would be coo...   Nov 22 2010, 12:12 PM
kg6dxn   Hmmm....a 13B-REW Rotary/Wankel motor would be co...   Nov 22 2010, 01:44 PM
Andyrew   So you decided 15mpg is still OK huh? :D Going ...   Nov 22 2010, 02:03 PM
kg6dxn   So you decided 15mpg is still OK huh? :D Going...   Nov 22 2010, 02:22 PM
strawman   When I was into MR2s (albeit the early models, not...   Nov 22 2010, 03:02 PM
kg6dxn   When I was into MR2s (albeit the early models, no...   Nov 22 2010, 03:36 PM
Andyrew   200ft lbs at what RPM? How much tq will you have ...   Nov 22 2010, 04:08 PM
kg6dxn   200ft lbs at what RPM? How much tq will you have...   Nov 22 2010, 05:34 PM
Andyrew   Wait, your using the 901 as a 4 speed or 5 speed? ...   Nov 22 2010, 05:59 PM
kg6dxn   Here's some stock specks from turborx7.com ...   Nov 22 2010, 07:23 PM
jmmotorsports   Here's some stock specks from turborx7.com ...   Nov 22 2010, 10:14 PM
kg6dxn   What V8 that will fit in a 914 weigh's 800 ...   Nov 22 2010, 10:24 PM
Lennies914   Mike, Do you already have a motor? There was a gu...   Nov 22 2010, 07:25 PM
kg6dxn   Mike, Do you already have a motor? There was a g...   Nov 22 2010, 07:30 PM
Andyrew   Thats the way to go.. Hack up the ECU yourself so ...   Nov 22 2010, 08:32 PM
matthepcat   Right on Mike! I would recommend muffling the...   Nov 23 2010, 05:41 PM
kg6dxn   Right on Mike! I would recommend muffling th...   Nov 23 2010, 05:50 PM
matthepcat   No that was a moment of weakness. I have been lurk...   Nov 23 2010, 06:16 PM
kg6dxn   Not much to update. I've been collecting parts...   Dec 11 2010, 06:40 PM
RJMII   So are you switching to single turbo with the b...   Dec 11 2010, 10:20 PM
kg6dxn   So are you switching to single turbo with the bal...   Dec 11 2010, 11:08 PM
Andyrew   I still think your going to be pushing way more HP...   Dec 11 2010, 11:12 PM
kg6dxn   I still think your going to be pushing way more H...   Dec 11 2010, 11:23 PM
Andyrew   Holy Shit, 2000CC? how many do you use? for the A4...   Dec 12 2010, 03:17 PM
kg6dxn   Holy Shit, 2000CC? how many do you use? for the A...   Dec 12 2010, 05:50 PM
oldschool   Holy Shit, 2000CC? how many do you use? for the ...   Dec 12 2010, 07:46 PM
Andyrew   Holy Shit, 2000CC? how many do you use? for the ...   Dec 12 2010, 08:59 PM
kg6dxn   To be perfectly honest, it sounds to me like you...   Dec 12 2010, 10:13 PM
kg6dxn   Oh, I forgot... Here are some pics for Oldschool....   Dec 12 2010, 10:17 PM
Andyrew   Is that an HTA compressor side? If so, SWEET!...   Dec 13 2010, 12:07 AM
kg6dxn   This pic is for Andrew. It shows the chosen turbo ...   Dec 13 2010, 07:11 PM
Andyrew   Not bad, A little low for the turbo size, but stil...   Dec 14 2010, 10:37 AM
kg6dxn   Quick update... Home refi has slowed down my purch...   Jan 18 2011, 10:05 PM
Rotary'14   Quick update... Home refi has slowed down my purc...   Jan 19 2011, 02:56 PM
oldschool   Quick update... Home refi has slowed down my pur...   Jan 19 2011, 08:12 PM
strawman   Lookin' good Mike! At the rate I've be...   Jan 19 2011, 03:06 AM
mikey63   How about (TT) TURBO TRANSFORMATION!   Jan 19 2011, 11:14 AM
914Timo   Could you show more pics about the front lights in...   Jan 22 2011, 01:28 PM
kg6dxn   Could you show more pics about the front lights i...   Jan 22 2011, 02:44 PM
roadster fan   Looking Good! surfer dudes would call it Tota...   Jan 22 2011, 10:21 PM
thenewwazoo   Just found your build - it looks nice! A few t...   Feb 16 2011, 01:00 AM
kg6dxn   Just found your build - it looks nice! A few ...   Feb 16 2011, 09:39 AM
Rotary'14   Just found your build - it looks nice! A few...   Feb 17 2011, 08:18 PM
kg6dxn   Got my V Band exhaust clamps in... 4 INCHES!...   Feb 17 2011, 08:05 PM
Andyrew   NICE! I love Vband clamps. 4" is Biiiig A...   Feb 17 2011, 08:07 PM
kg6dxn   NICE! I love Vband clamps. 4" is Biiiig ...   Feb 17 2011, 08:20 PM
ChrisNPDrider   I thought "TT" meant Targa Top? :D You...   Feb 17 2011, 10:03 PM
kg6dxn   My adapter showed up. Now i can finish the fab of ...   Mar 6 2011, 01:11 AM
kg6dxn   Another...   Mar 6 2011, 01:12 AM
kg6dxn   I did some work inside. I welded a bracket that bo...   Mar 6 2011, 01:18 AM
kg6dxn   Now I have to figure out where I am putting my boo...   Mar 6 2011, 01:23 AM
kg6dxn   Now for the sad part. My car is outside! I was...   Mar 6 2011, 01:25 AM
Andyrew   Mike it looks like your making great progress...   Mar 6 2011, 04:10 AM
Lennies914   You are moving right along! Everythings lookin...   Mar 6 2011, 10:14 AM
kg6dxn   Thanks for the support guys! For the historic...   Mar 6 2011, 11:46 AM
kg6dxn   I forgot to mention. I found some major California...   Mar 7 2011, 09:51 PM
Lennies914   I forgot to mention. I found some major Californi...   Mar 7 2011, 09:55 PM
kg6dxn   More...   Mar 7 2011, 09:53 PM
roadster fan   :headbanger: Looking good, keep up the good work...   Mar 7 2011, 10:01 PM
Andyrew   My honda has more rust than that!   Mar 7 2011, 11:11 PM
kg6dxn   I finally got my engine mount finished and install...   Mar 20 2011, 04:48 PM
kg6dxn   Here's another pic. The rain in Cali is really...   Mar 20 2011, 04:49 PM
kg6dxn   I have also been working on my trailer hitch. I to...   Mar 20 2011, 07:26 PM
kg6dxn   More...   Mar 20 2011, 07:27 PM
kg6dxn   More...   Mar 20 2011, 07:29 PM
kg6dxn   Goober welds... Before I added gas to my mig welde...   Mar 20 2011, 07:32 PM
kg6dxn   The money shot. Can't even see the motor hardl...   Mar 20 2011, 07:35 PM
Andyrew   I like it all!!! Remember to primer ...   Mar 21 2011, 09:38 AM
kg6dxn   I like it all!!! Remember to primer...   Mar 21 2011, 09:50 AM
Andyrew   Ahh, that makes more sense. I didnt put 2 and 2 to...   Mar 21 2011, 10:10 AM
ChrisNPDrider   Awesome progress! I feel your pain about havin...   Mar 21 2011, 12:08 PM
kg6dxn   Tossed the bumper on for some quick pics. The old ...   Mar 21 2011, 10:13 PM
JRust   Looking good Mike! Keep up the good work   Mar 21 2011, 10:42 PM
Andyrew   Looks Awesome Mike! One of those mods that I ...   Mar 22 2011, 08:24 AM
kg6dxn   Whats next? Injectors 4@ $180 each, 2-850cc...   Mar 22 2011, 09:27 AM
Andyrew   Ouch! The little stuff just adds right up..   Mar 22 2011, 09:39 AM
trojanhorsepower   Injectors 4@ $180 each, 2-850cc, 2-1600cc Fu...   Mar 22 2011, 06:15 PM
Lennies914   Injectors 4@ $180 each, 2-850cc, 2-1600cc F...   Mar 22 2011, 08:58 PM
campbellcj   LOL...whenever you get the empty wallet blues, jus...   Mar 22 2011, 09:36 PM
kg6dxn   Did some more work in the trunk today. Cut out the...   Mar 26 2011, 07:30 PM
kg6dxn   Got it trimed and welded. I also welded in some 1....   Mar 26 2011, 07:33 PM
kg6dxn   Got everything tied in and primered...   Mar 26 2011, 07:35 PM
kg6dxn   Strawman get me thinking about the engine bar moun...   Mar 26 2011, 07:38 PM
kg6dxn   I beefed up the engine mounts with some 14ga steel...   Mar 27 2011, 08:30 PM
4 Pages V  1 2 3 > »
22 User(s) are reading this topic (22 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 25th November 2024 - 11:33 PM
