Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
For those who don't know me or the car, I have a '74 914 that is a dedicated AX car. It previously had a high compression 2.7 6-cylinder motor and made 205hp/205ft-lbs at the wheels. This set-up wasn't all that bad considering that it won the 2008 and 2009 914 Shootout events, however the quest for more speed continues.
Here is the car in the 2010 season trim. (IMG:http://www.914world.com/bbs2/uploads_offsite/dragracevws.com-364-1291656786.1.jpg) I have recently sold the 2.7L 6-cylinder engine and all the remaining 914/6 conversion parts. I have used the proceeds to fund the conversion to Subaru power. Now most would say that a Subaru conversion can be done on a budget, however I have found that the money goes flying out the window when doing something like this. Regarding the engine...logical choice would be to go for a EJ257 2.5L USDM STi engine. However, all the SCCA rules for AX are built around displacement which in turn dictates the minimum weight. Therefore, I have gone with a JDM STi version8 Spec-C engine which is a 2.0L, twin-scroll, hand ported/polished, 8500rpm animal. I will get slightly less hp and torque numbers than the 2.5L, but save 150lbs of weight. |
ottox914 |
The glory that once was. ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest ![]() ![]() |
You have probably researched this and thought it thru already, but since you are in the install/set-up/plumbing phase, how about preping for E85 and getting a hot tune for that corn hooch. I'd bet 400hp easy.
Britain Smith |
You have probably researched this and thought it thru already, but since you are in the install/set-up/plumbing phase, how about preping for E85 and getting a hot tune for that corn hooch. I'd bet 400hp easy. The fuel system is prep'ed for E85, however I am going to continue using my 110octane leaded fuel for the time being. It will give the same performace gains and I have ~30gallons left over from last season. Not going to get 400hp, but hopefully close. -Britain |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:53 AM |
