Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
For those who don't know me or the car, I have a '74 914 that is a dedicated AX car. It previously had a high compression 2.7 6-cylinder motor and made 205hp/205ft-lbs at the wheels. This set-up wasn't all that bad considering that it won the 2008 and 2009 914 Shootout events, however the quest for more speed continues.
Here is the car in the 2010 season trim. (IMG:http://www.914world.com/bbs2/uploads_offsite/dragracevws.com-364-1291656786.1.jpg) I have recently sold the 2.7L 6-cylinder engine and all the remaining 914/6 conversion parts. I have used the proceeds to fund the conversion to Subaru power. Now most would say that a Subaru conversion can be done on a budget, however I have found that the money goes flying out the window when doing something like this. Regarding the engine...logical choice would be to go for a EJ257 2.5L USDM STi engine. However, all the SCCA rules for AX are built around displacement which in turn dictates the minimum weight. Therefore, I have gone with a JDM STi version8 Spec-C engine which is a 2.0L, twin-scroll, hand ported/polished, 8500rpm animal. I will get slightly less hp and torque numbers than the 2.5L, but save 150lbs of weight. |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
When the vss was sold to me I think I remember it gives way less pulses than the suby tranny. It's not enough to run a electric speedo so my thinking was it won't run the ecu for any more than fail safe limp home avoidance.
I wouldn't start the motor without veryfying a good pickup clearance if it was mine. My son uses open source also and I am planning on his support on mine but it isn't going to be avcs although we do have his original low miles 04 sti motor complete in my garage. My understanding of twin scroll is the ports were put in the tubes to keep the velocity up and the pulses smoother. Smaller tubes is more velocity and putting the ports in the tubes that way means smooth pulses. We will see, thats the good thing about hot rodding and all the good ideas. I personally like to keep it as simple as possible to eliminate things breaking. |
Lo-Fi Version | Time is now: 20th June 2024 - 09:05 AM |
