Out with the old...in with the new...Britain's Racecar Development, Subaru Engine, Lotus Suspension! Time to go racing! |
Britain Smith |
Dec 6 2010, 11:33 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
For those who don't know me or the car, I have a '74 914 that is a dedicated AX car. It previously had a high compression 2.7 6-cylinder motor and made 205hp/205ft-lbs at the wheels. This set-up wasn't all that bad considering that it won the 2008 and 2009 914 Shootout events, however the quest for more speed continues.
Here is the car in the 2010 season trim. (IMG:http://www.914world.com/bbs2/uploads_offsite/dragracevws.com-364-1291656786.1.jpg) I have recently sold the 2.7L 6-cylinder engine and all the remaining 914/6 conversion parts. I have used the proceeds to fund the conversion to Subaru power. Now most would say that a Subaru conversion can be done on a budget, however I have found that the money goes flying out the window when doing something like this. Regarding the engine...logical choice would be to go for a EJ257 2.5L USDM STi engine. However, all the SCCA rules for AX are built around displacement which in turn dictates the minimum weight. Therefore, I have gone with a JDM STi version8 Spec-C engine which is a 2.0L, twin-scroll, hand ported/polished, 8500rpm animal. I will get slightly less hp and torque numbers than the 2.5L, but save 150lbs of weight. |
Britain Smith |
Dec 15 2010, 12:39 PM
Couple of updates while the engine is out a shop getting all the exhaust tig welded.
Some of you might have noticed in the previous picture of the radiator that the fan was mounted about an inch from the radiator. Not sure why they built it that way, but I modified the fan mounts to move it about 1/4" from the radiator. This will be much more efficient. I also had some tabs welded on for the mounts to the chassis. (IMG:http://www.914world.com/bbs2/uploads_offsite/l7.sphotos.l3.fbcdn.net-364-1292438351.1.jpg) Also made a bracket to hold the three master cylinder reservoirs in the front. I am mounting a Tilton brake pedal assembly and converting the clutch to a hydraulic throw-out bearing hence the need for this set-up. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1292438352.2.jpg) -Britain |
Lo-Fi Version | Time is now: 20th June 2024 - 08:54 AM |
