> Taco plate leak - Need you help / inside, Did you have the same issue??
draganc
post Dec 9 2010, 02:45 PM
Hi everybody,
I’m having a leak issue at the taco place and was wondering if you have some advice or experienced similar issue.
It appears that the plate leaks only in one area – see picture. The engine has been sitting on my work bench for a few months after rebuild, hence is leaking even at cold temp.
- I checked the plate on a mirror and it appears to be flat and the overall condition looks very good – no nicks nor bents or scratches at the sealing surface.
- New o-ring and copper washer have been installed.
- The M6x10 hex screws have been tighten to spec.
- The crank opening measures 84.2mm, the taco plate’s o-ring surface measures 76mm and the o-ring is 4mm thick.
It takes only a little bit of force to put the plate in place with mounted o-ring and it appears that plate is already touching the crank-case w/o torquing down the screws.
Any ideas or suggestions?
Thanks,
Dragan
Black22
post Dec 15 2010, 11:23 PM
Where did you order that shiny taco from? I want one!!
- Lo-Fi Version Time is now: 31st October 2024 - 06:17 PM
