> karlo's 914 V8 adventures, ... and misadventures
karlo
post Nov 21 2010, 10:16 PM
Karl Anders Øygard
Hi all!
Real short introduction. I'm on a three month leave here in San Diego, with my wife and 3 month old daughter. I live in Norway, but my American wife has family here, and winter is a great time to visit. It gets cold in Norway... I have a BMW 635CSi and a Citroen SM in Norway, but that's a different topic altogether.
On to business. I have a 1974 914 (4742921095) that has been an AX car for the last ten years. My plan is to make the car more presentable--when I got it, it was quite rough. It's an SBC V8 build with a 915 transaxle and various 911 suspension parts. More about that later. The car doesn't look so good right now, in particular I don't like the flares, so I'm going to do a fairly thorough restoration. Not too much rust on the car, but it probably needs dealing with anyways. Here's the beauty:
(IMG:http://www.914world.com/bbs2/uploads_offsite/people.opera.com-10999-1290399407.1.JPG)
I bought this car from nocones last year, and it's been sitting for most of that time, due to a broken transmission (and also I've been back in Norway). During some fairly normal driving, it popped out of third gear and self destructed. I wasn't in the car at the time, so I'm not really sure what happened. Only inspection will tell.
So, out the trans comes.
Unscrewed the drain plug. This does not bode well:
More carnage is visible once the nosecone is off:
I need bigger tools to get the fifth gear and reverse off, so I can't get to the innards where the real action is right now. Will investigate that tomorrow. I found parts of what I suspect is a grenaded second gear. It remains to be seen whether the transmission is a lost cause. Input is appreciated. Maybe I should just get a 930 and be done with it...
More tomorrow.
- Karl
karlo
post Dec 16 2010, 11:36 PM
Karl Anders Øygard
Sounds like I need to pay you a visit. (IMG:style_emoticons/default/smile.gif)
Need to fix the transaxle first, so the car can be moved. I believe I have all the parts to fix it now.
karlo   karlo's 914 V8 adventures   Nov 21 2010, 10:16 PM
sean_v8_914   Jackque at scotts porsche has a donor 915 for part...   Nov 21 2010, 10:34 PM
karlo   Yep, located at Rancho Peñasquitos. Maybe I'l...   Nov 21 2010, 10:46 PM
karlo   Got hold of some bigger tools, and pulled off 5th ...   Nov 22 2010, 11:06 PM
karlo   Caught a cold today, so nothing of interest happen...   Nov 23 2010, 04:26 PM
Dr Evil   Your slider is worn, that is why it popped out mos...   Nov 23 2010, 04:48 PM
karlo   Thanks for the insight. That's what I'm th...   Nov 23 2010, 05:03 PM
karlo   The Oceanside lead turned up empty, so no help the...   Nov 24 2010, 10:48 PM
karlo   Digging into rust issues while I'm considering...   Nov 29 2010, 10:10 PM
SirAndy   The driver's side hell hole has had standing w...   Nov 30 2010, 12:41 AM
karlo   There are actually two plastic plugs, one larger ...   Nov 30 2010, 07:35 PM
brilliantrot   I would also suggest that you replace the main sha...   Nov 30 2010, 12:38 AM
karlo   Pictures of the hell holes, as promised, treated a...   Nov 30 2010, 09:20 PM
karlo   Rust removal continues. Have been derusting the he...   Dec 15 2010, 09:44 PM
sean_v8_914   ...and the vertical wall (inner wheel house)behind...   Dec 16 2010, 08:16 AM
sean_v8_914   snap a photo of the seam under teh hell hole. the ...   Dec 16 2010, 08:25 AM
karlo   Got a better picture of the underside of the LHS l...   Dec 16 2010, 01:28 PM
sean_v8_914   viva la plasma cutter   Dec 16 2010, 10:56 PM
karlo   Sounds like I need to pay you a visit. :) Need to...   Dec 16 2010, 11:36 PM
sean_v8_914   it is MUCH better to do the chassis work while the...   Dec 17 2010, 08:31 AM
sean_v8_914   exp   Dec 17 2010, 08:34 AM
sean_v8_914   I like this one too but doesnt show area of discus...   Dec 17 2010, 08:36 AM
sean_v8_914   since we are talking about messed up chassis...cen...   Dec 17 2010, 08:37 AM
roadster fan   This is not the best pic but may be helpful Jim   Dec 18 2010, 05:13 PM
karlo   This is not the best pic but may be helpful Ji...   Dec 18 2010, 07:07 PM
sean_v8_914   thank you. that view shows the two different layer...   Dec 19 2010, 08:38 AM
karlo   The car has found its way to Sean's shop where...   Jan 8 2011, 02:51 AM
sean_v8_914   assemble and run it till it spits chuncks   Jan 8 2011, 09:27 AM
sean_v8_914   grinding, cleaning, cutting...   Jan 17 2011, 11:42 AM
sean_v8_914   compared to others, this chassis is fairly solid. ...   Jan 22 2011, 11:02 AM
sean_v8_914   the rust seems to weaken the spot welds. then they...   Jan 22 2011, 11:09 AM
sean_v8_914   My friend Bruce Stone, known here as the Porsche p...   Jan 22 2011, 11:24 AM
sean_v8_914   this might be overkill but Im playing with it htt...   Jan 22 2011, 11:39 AM
sean_v8_914   the images with "sm" at the end of the n...   Jan 22 2011, 11:40 AM
karlo   While the car is in for welding, I've been wor...   Jan 25 2011, 03:34 AM
sean_v8_914   that stupid crack by the E brake made me chase it ...   Jan 25 2011, 08:21 AM
Dr Evil   good thing I can still hold my breath for about 2...   Jan 25 2011, 09:16 AM
sean_v8_914   (tax payer financed) Navy training to hold breath ...   Jan 25 2011, 09:34 AM
Dr Evil   As a Yeoman? Are you still BSing people about your...   Jan 25 2011, 10:08 AM
kg6dxn   F-ing Squids... :poke: SEMPER FI :beer2:   Jan 25 2011, 10:38 PM
sean_v8_914   no, actually I was a nurse in the coast guard   Jan 26 2011, 01:35 AM
sean_v8_914   for some odd reason the chassis rail from teh rt s...   Jan 26 2011, 01:51 AM
sean_v8_914   my harbour freight stud welder died so I welded on...   Jan 26 2011, 01:54 AM
76-914   The Navy was created so Marines would have someone...   Jan 26 2011, 09:03 AM
sean_v8_914   Marines were the onboard security force of the Nav...   Jan 26 2011, 11:25 AM
914.SBC   Marines were the onboard security force of the Na...   Jan 26 2011, 03:34 PM
sean_v8_914   the coolign system is early Renegade fro when they...   Jan 26 2011, 05:13 PM
karlo   345 hp @ 5200, 387 lb-ft @ 3250. The carb setup re...   Jan 26 2011, 11:08 PM
sean_v8_914   those Edlebrock carbs are about $250 new and ...   Jan 26 2011, 11:24 PM
karlo   Good tip. I'd have to learn something about ca...   Jan 27 2011, 02:39 AM
karlo   Some updates I got from Sean: The usual crack in ...   Feb 5 2011, 09:59 PM
sean_v8_914   here's an ugly one. I cant find the pic from u...   Feb 6 2011, 12:07 PM
karlo   More pictures from Sean: Acid etched, rust passiv...   Feb 12 2011, 02:56 AM
karlo   Next in line is welding in steel flares, full repa...   Feb 12 2011, 03:25 AM
karlo   More updates from Sean: Stealth GT. Too dark t...   Feb 18 2011, 11:45 PM
karlo   SEM epoxy seam sealed, wurth etching primer, wurth...   Feb 19 2011, 12:13 AM
karlo   Further issues with the 911 ebrake setup. The ebr...   Feb 20 2011, 11:34 AM
karlo   The ring and pinion was in excellent shape, so was...   Feb 20 2011, 12:26 PM
sean_v8_914   more quaiffe photos please so we can all drool and...   Feb 21 2011, 10:55 AM
abnrdo   Very nice! I am interested in how your body ...   Feb 21 2011, 11:36 AM
karlo   I forget the specifics, but Sean can probably fill...   Feb 21 2011, 02:24 PM
25 User(s) are reading this topic (25 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th December 2024 - 01:05 AM
