Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
For those who don't know me or the car, I have a '74 914 that is a dedicated AX car. It previously had a high compression 2.7 6-cylinder motor and made 205hp/205ft-lbs at the wheels. This set-up wasn't all that bad considering that it won the 2008 and 2009 914 Shootout events, however the quest for more speed continues.
Here is the car in the 2010 season trim. (IMG:http://www.914world.com/bbs2/uploads_offsite/dragracevws.com-364-1291656786.1.jpg) I have recently sold the 2.7L 6-cylinder engine and all the remaining 914/6 conversion parts. I have used the proceeds to fund the conversion to Subaru power. Now most would say that a Subaru conversion can be done on a budget, however I have found that the money goes flying out the window when doing something like this. Regarding the engine...logical choice would be to go for a EJ257 2.5L USDM STi engine. However, all the SCCA rules for AX are built around displacement which in turn dictates the minimum weight. Therefore, I have gone with a JDM STi version8 Spec-C engine which is a 2.0L, twin-scroll, hand ported/polished, 8500rpm animal. I will get slightly less hp and torque numbers than the 2.5L, but save 150lbs of weight. |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,316 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
I would consider modifying or adding some kind of rubber spacing on the radiator. It all looks to be hardmounted. If you get flex up front with it hard mounted your radiator won't last to long. It needs to have some mounts that allow for flex. I know that was why renegade went to a floating radiator setup. Still pretty firm in place but does move enough to allow for flex (IMG:style_emoticons/default/confused24.gif) .
Of course most of what you are doing is over my head anyway (IMG:style_emoticons/default/sad.gif) . It being the shitbox it is probably reinforced up there so flex isn't an issue. This is as close to helping as I will probably get (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:49 AM |
