Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,345 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
Since the NSX had a 2 pane rear window I was wondering if it would be worth it for the 914? I know the NSX has a vacuum in between to cut sound transmission that would be hard to create.
The 914 has the room on the "ledge" for 2 and a gap (5mm + 5mm + 5mm). fire away (IMG:style_emoticons/default/fighting19.gif) (IMG:style_emoticons/default/chatsmiley.gif) (IMG:style_emoticons/default/smile.gif) |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Ok, here's the latest from my research with a couple of local glass guy's I work with.
First, they both said that unsupported on the bottom, the inside glass would sag and the seal would fail. Second (to my surprise), the laminated glass would give almost the same sound and temp insulating qualities as the the insulated unit. Third, both said they could not make the insulated unit knowing what it was meant for ( implied laibility). Fourth, the insulated unit would be too damn thick to fit behind the trim panels. My consensus. Just leave it like it is untill you have to change it. |
Lo-Fi Version | Time is now: 24th June 2024 - 11:18 PM |
