> Bought a 914 race car and need help to Id the year of some parts
porsche4me
post Dec 25 2010, 02:20 PM
Hello - I have a new (to me) 914 race car that was made from at least 3 parts cars - and Now I am trying to buy parts and need help..... The body - no a- pillars no windshield ---- front pass fender has a welded plate for the cage over the vin --- no bumpers and holes drilled all over the front area --- I destroyed a firewall shift bushing that I bought (did the hot water and all) and now I think it could be for the wrong car year.
-- How to ID the body year ???? pass side floor has seat hinges , if that helps.
I also need help with front end id, how to tell if the front susp is early or late ??? and calipers ??? ------ the rear trailing arms, how to Id early from late --- I have the calipers off the car --
I got 4 trailing arms and 2 complete front susp -- with the car , but need to id them to buy spare parts....
is there a good place to see pixs??? I have searched sites and googled but never come up with what I need -----
__________________
Dr Evil
post Dec 26 2010, 01:26 PM
Send me your transmission!
73-74, there are obvious dog bone holes and no large holes where the bumper shox would be. The bushing you destroyed trying to place was likely for a 70-72 as it will be larger ID and OD than the later style. It will not fit. The ID should be way to big for your shift shaft, and this is an easy check for you. Hinged seats started in 73.
r_towle
post Dec 26 2010, 05:25 PM
Custom Member
QUOTE(Dr Evil @ Dec 26 2010, 02:26 PM) *
Hinged seats are in mid 72.
There are three bushings out there.
Two sized holes in the tub.
Early cars up to 73 had tail shifters and the hole in the tub was large.
Tail shifter linkage rod is larger than the side shifter.
That bushing is large outer diameter, large inner diameter.
Second simple bushing is from 73 an up for the side shifter.
Smaller hole in the tub
Smaller shift rod.
That bushing has a smaller diameter inner hold and smaller diamter outer hole.
third bushing is to allow you to put a side shifter tranny into the early tub.
That one has a large outer diameter outside, and the smaler diameter inside for the side shifter rod.
Take a picture straight down into the front trunk.
This will show you the floor supports at the front of the trunk floor.
Those change in late 72
Take a picture of the rear lower firewall that the shifter rod comes out from below and outside the passenger compartment.
With those two pics, you can identify the tub year.
If its all welded together from two or three tubs...all bets are off.
Rich
porsche4me   Bought a 914 race car and need help to Id the year of some parts   Dec 25 2010, 02:20 PM
d914   post pics, 5 lug or 4?? If five lug and 3" sp...   Dec 25 2010, 02:28 PM
type47   pass side floor has seat hinges adjustable pas...   Dec 25 2010, 02:46 PM
kg6dxn   :ttiwwp:   Dec 25 2010, 03:04 PM
ChrisNPDrider   :agree:   Dec 25 2010, 06:08 PM
porsche4me   I dont have the newer pix on this computer ---- It...   Dec 25 2010, 11:43 PM
KaptKaos   '75 or '76 front end. Looks like there is...   Dec 26 2010, 02:02 AM
RobW   It looks like there are remnants of a vin tag on t...   Dec 26 2010, 07:34 AM
davep   check for data at these locations   Dec 26 2010, 08:20 AM
jt914-6   With "Perfection Plus" on the rear fende...   Dec 26 2010, 08:48 AM
Dr Evil   73-74, there are obvious dog bone holes and no lar...   Dec 26 2010, 01:26 PM
KaptKaos   73-74, there are obvious dog bone holes and no la...   Dec 26 2010, 01:41 PM
r_towle   The bushing you destroyed trying to place was lik...   Dec 26 2010, 05:25 PM
Dr Evil   Those holes you circled on the far right of the fr...   Dec 26 2010, 01:49 PM
sixnotfour   The shape of headlight bucket , and the lower whee...   Dec 26 2010, 03:33 PM
cwpeden   Late firewall has different seabelt holes. Is...   Dec 26 2010, 04:00 PM
kg6dxn   There should be a VIN stamped into the top, inner ...   Dec 26 2010, 04:05 PM
brant   why did the original owner strip it to use the par...   Dec 26 2010, 04:07 PM
SirAndy   '75/'76 chassis for sure. Dead giveaway i...   Dec 26 2010, 07:41 PM
Dr Evil   '75/'76 chassis for sure. Dead giveaway ...   Dec 26 2010, 10:48 PM
porsche4me   Wow - great info guys ----- I will shoot lots of p...   Dec 26 2010, 08:17 PM
SLITS   now on to the front susp ---- how do I tell ear...   Dec 27 2010, 11:36 AM
porsche4me   the dog bone holes were drilled after factory ----...   Dec 26 2010, 08:21 PM
jjackson   It's a 76 that I bought from a guy in Cary, No...   Dec 26 2010, 08:29 PM
jjackson   I just went back and read all posts-that was prett...   Dec 26 2010, 08:50 PM
porsche4me   Thank you Mr. Jackson - great to text with you - -...   Dec 26 2010, 09:08 PM
porsche4me   You are correct about it being stripped out --- th...   Dec 26 2010, 09:13 PM
jjackson   Any information you need-Do not hesitate.When you ...   Dec 26 2010, 09:35 PM
porsche4me   Thanks --- it will be all 4 bolt stuff ---- I foun...   Dec 26 2010, 10:02 PM
ChrisNPDrider   To read some excellent posts on brakes and early v...   Dec 26 2010, 10:13 PM
- Lo-Fi Version Time is now: 15th January 2025 - 06:38 AM
