> front a arm bushings, update: URO bushings installed thanks PMB
silver74insocal
post Dec 29 2010, 10:30 PM
ive searched and cant find any feed back on these (other then 2 less then favorable reviews on the bird site)
the price is right but is it worth the hassle? mine are pretty mushroomed so i think anything is better then what ive got...but i am on a budget (IMG:style_emoticons/default/sad.gif)
any feed back on these would be great (IMG:style_emoticons/default/beerchug.gif) Dave
detoxcowboy
post Dec 29 2010, 10:40 PM
Region Association: Africa
I did not like them, polygraphite has to be precision bored to fit right like a bearing, they need to slip as they are NOT static like the rubber ones. Delrin is better but also need to be precisely bored to fit for same reason.. The rubber ones at Pelican are expensive but quality and rubber is static so they just sort of twist and not slip fit like a bearing.
Here is a rubber set that is not hundreds of dollars, but about $60 for the budget/ the poly graphite used to be $70 when they first came out, and people did have problems..
http://www.automotion.com/neatrix-front-a-...or-porsche.html
and another source oem ect..
http://www.sierramadrecollection.com/store...tail&p=3638
I tried both poly graphite and delrin and did the home boring (should have went to a machine shop) with a brake hone and had rattling on a couple, and on the other set I did not bore enough and the supsension would not move or do not listen to the lie that they will break in after 30 days, I needed a kidney belt after one 3 hour drive trying to break them in..
Then there is the issue of sag and how long will plastic of any type really hold up or last? At first they sold as the ultimate and now well the price is dirt cheap and everything else speaks for itself.. Rubber stock lasted this long, so probabaly get a good run out of more rubber..
Oh and one hint fire is your friend, torch out the old ones if you can't get them loose... Lot's of dish soap and water to get the new ones on, I did not have a vice big enough so I used long plastic clamps that have a hand squeeze trigger like you would buy at home depot.. and make certain they are on all the way before the soap starts to dry and they get stuck solid.. quick! firm! slippery! you can put them on the car immeadiately if your carefull not to lose position that way you can check that they are indexed properly for fit and function, then I waited overnight before I drove, perfect ever since..
It was alot of work for me to do the whole car 3 times, but I must say I am happy with the rubber and it gives a softer stock ride..
The other is more like a dance when done correctly I am told.. But I will probably never know.
silver74insocal   front a arm bushings   Dec 29 2010, 10:30 PM
detoxcowboy   I did not like them, polygraphite has to be precis...   Dec 29 2010, 10:40 PM
silver74insocal   thanks detox!! :Qarl: :Qarl: exactly wha...   Dec 29 2010, 11:24 PM
jcd914   I have good luck with the polygraphite bushing. Th...   Dec 29 2010, 11:50 PM
kconway   I did the Elephant Racing rubber bushings front an...   Dec 30 2010, 02:13 AM
Eric_Shea   These are kinda pricey but they will last. http:/...   Dec 30 2010, 02:07 PM
silver74insocal   are you referring to the Neatrix bushings? i plan...   Dec 30 2010, 03:12 PM
Als914   ive searched and cant find any feed back on these...   Dec 30 2010, 02:26 PM
Eric_Shea   There's a ton of people here running them. I ...   Dec 30 2010, 02:32 PM
Als914   There's a ton of people here running them. I...   Dec 30 2010, 03:13 PM
treborzerimar   I had the hard plastic-type bushings on my car tha...   Dec 30 2010, 02:46 PM
silver74insocal   I had the hard plastic-type bushings on my car th...   Dec 30 2010, 03:30 PM
silver74insocal   great responses as usual fellas! i should have...   Dec 30 2010, 02:59 PM
Eric_Shea   I tend to use the "Pareto principle" the...   Dec 30 2010, 03:41 PM
silver74insocal   thats perfect Eric thanks...lemme know and i will ...   Dec 30 2010, 03:56 PM
r_towle   I went from stock old worn out bushings to two set...   Dec 30 2010, 04:06 PM
dion9146   My next car will have rubber...no need to change ...   Dec 30 2010, 04:44 PM
Eric_Shea   You can measure them... top and bottom. Check t...   Dec 30 2010, 05:15 PM
Eric_Shea   Found'em... [url=http://www.youtube.com/wat...   Dec 30 2010, 05:41 PM
detoxcowboy   "I went from stock old worn out bushings to t...   Dec 30 2010, 08:18 PM
treborzerimar   Silver - As for the poor fir of my "hard...   Dec 30 2010, 08:45 PM
silver74insocal   thanks Robert and Richard and thanks to all who sh...   Dec 30 2010, 08:52 PM
draganc   perfect timing! did anyone try these before: ...   Dec 30 2010, 11:04 PM
kconway   believe I got these from Eric as he supplies ER bu...   Dec 31 2010, 01:29 AM
sean_v8_914   i think it is funny that I have installed more A a...   Dec 31 2010, 07:40 AM
Eric_Shea   I'm growing weary of group buys but I put a po...   Dec 31 2010, 11:41 AM
silver74insocal   well i have had these URO bushings in for about a ...   Feb 21 2011, 12:09 AM
Gint   That's cool and everything, but what do you us...   Feb 21 2011, 08:37 AM
kconway   I used rubber rear bushings to compliment the rubb...   Feb 21 2011, 08:38 AM
Gint   Where did you get new rubber rear bushings?   Feb 21 2011, 08:39 AM
kconway   PMB, Elephant racing...not inexpensive tho. http:...   Feb 21 2011, 08:41 AM
Gint   Cool. Last I read, Eric didn't have rears (or...   Feb 21 2011, 08:44 AM
Eric_Shea   I sell all of the Elephant products. There's ...   Feb 21 2011, 12:39 PM
rdauenhauer   In replacing the Fronts, the OE Rubber bushings we...   Feb 21 2011, 02:52 PM
kconway   I used the ER version, and the instructions/video ...   Feb 21 2011, 04:00 PM
nsyr   It would be nice if ER offered just their bushings...   Feb 21 2011, 05:33 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 07:57 PM
