Problem with Elephant Poly Bronze Front Bushings, Whipped it! Now swinging freely! |
bobhasissues |
Dec 31 2010, 03:28 PM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
Installed the poly bronze front bushings last spring. They were binding. To alleviate some of the binding I bought, from McMaster Carr, spherical washers for the frontside mounts. This helped quite a lot, but there was still a bit of binding. I figured I also needed spherical washers on the backside mounts as well to get these things to rotate without binding. My plan was to replicate the $200 Elephant backside mounts by machining enough material off the top and bottom sides of the backside mounts to accommodate spherical washers. I began this project today.
When I started to take the control arms off the car, every one the base (concave) sides of the washers fell off in pieces. I couldn't believe it. When I assembled this stuff I only gave them a good snug down with a socket wrench, no over tightening. I do not want to continue this project and modify the backside mounts if the conical washers cannot hold up. These are the washers I bought for the front mounts, same manufacturer for the backs, just a larger size. I bought case hardened steel rather than stainless due to the 12 sets x $15 per set price difference. Has anyone had a similar experience? Any advise to help me get this resolved will be greatly appreciated. |
ChrisFoley |
Dec 31 2010, 05:21 PM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Binding through only a portion of the motion range seems to indicate a lack of co-linearity of the a-arm bushing surfaces, and not a problem with alignment of the bushings themselves.
Lo-Fi Version | Time is now: 26th June 2024 - 03:34 AM |
