bobhasissues |
seemingly endless issues with my 914 ![]() ![]() Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None ![]() |
Installed the poly bronze front bushings last spring. They were binding. To alleviate some of the binding I bought, from McMaster Carr, spherical washers for the frontside mounts. This helped quite a lot, but there was still a bit of binding. I figured I also needed spherical washers on the backside mounts as well to get these things to rotate without binding. My plan was to replicate the $200 Elephant backside mounts by machining enough material off the top and bottom sides of the backside mounts to accommodate spherical washers. I began this project today.
When I started to take the control arms off the car, every one the base (concave) sides of the washers fell off in pieces. I couldn't believe it. When I assembled this stuff I only gave them a good snug down with a socket wrench, no over tightening. I do not want to continue this project and modify the backside mounts if the conical washers cannot hold up. These are the washers I bought for the front mounts, same manufacturer for the backs, just a larger size. ![]() I bought case hardened steel rather than stainless due to the 12 sets x $15 per set price difference. Has anyone had a similar experience? Any advise to help me get this resolved will be greatly appreciated. |
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
I made my own "low friction" mounts and I bought my washers from Fastenal. I will check on them tomorrow and see if they are in as bad of shape as yours; I know they have some rust on them in the first year...
If you are still having binding issues then you may want to modify the rear A-arm mounts. If I recall correctly it took a lot of fiddling until I was happy with the movement of the arms. also remember the A-arm only travels so much and you dont need to worry about binding in the areas of non travel. I can search for pictures of my install if it will help you. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:23 AM |
