Problem with Elephant Poly Bronze Front Bushings, Whipped it! Now swinging freely! |
bobhasissues |
Dec 31 2010, 03:28 PM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
Installed the poly bronze front bushings last spring. They were binding. To alleviate some of the binding I bought, from McMaster Carr, spherical washers for the frontside mounts. This helped quite a lot, but there was still a bit of binding. I figured I also needed spherical washers on the backside mounts as well to get these things to rotate without binding. My plan was to replicate the $200 Elephant backside mounts by machining enough material off the top and bottom sides of the backside mounts to accommodate spherical washers. I began this project today.
When I started to take the control arms off the car, every one the base (concave) sides of the washers fell off in pieces. I couldn't believe it. When I assembled this stuff I only gave them a good snug down with a socket wrench, no over tightening. I do not want to continue this project and modify the backside mounts if the conical washers cannot hold up. These are the washers I bought for the front mounts, same manufacturer for the backs, just a larger size. I bought case hardened steel rather than stainless due to the 12 sets x $15 per set price difference. Has anyone had a similar experience? Any advise to help me get this resolved will be greatly appreciated. |
sean_v8_914 |
Jan 1 2011, 10:49 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
isnt case hardened brittle vs SS being more maluable ?
I think some a amrms are better than others. some installs have been a pain while others went smooth although ALL required slow torquing sequences |
J P Stein |
Jan 1 2011, 11:07 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Lo-Fi Version | Time is now: 26th June 2024 - 03:28 AM |
