C.Plavan |
Newbie ![]() Group: Members Posts: 37 Joined: 27-March 05 From: Clovis, California Member No.: 3,825 Region Association: None ![]() |
I'm a 914 newbie, but not a 911 newb. I was going to buy this car for a race car project. I showed the pictures to a fellow 914 racer and he had some concerns about the Hell Hole area. I figured I could just weld over the spot to strengthen, but from what I understand it could be more than just the hole that shows damage.
So after doing some more research, I'm even more concerned. I asked the seller to send me more pictures of this area from the top, bottom, and from the wheel well area. Just looking for some more guidance, should I pass on it and look for a different car? I'm thinking it may not be worth the headache. Your thoughts? ![]() |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
That's one nice 9eleben. (IMG:style_emoticons/default/biggrin.gif)
As for a parts car, I'd wait till you after find something you want. From what I could see, the other car will still be around..& cheeper....if you still need parts. Too many "ughknowns" to trust anything on it. |
C.Plavan |
That's one nice 9eleben. (IMG:style_emoticons/default/biggrin.gif) As for a parts car, I'd wait till you after find something you want. From what I could see, the other car will still be around..& cheeper....if you still need parts. Too many "ughknowns" to trust anything on it. Thanks- I love that Blue monster. Would it change your mind if the 914 had a fully welded in roll cage already done by a well known professional in the area? The cage is not a hack job. Its good. It is also tied to the susp points. Would you overlook the rockers knowing the car is stiff? The car is priced well under the cost of the cage itself, full 911 susp, sway bar, fuel safe fuel cell, two setrab oil coolers, rear 5 lug, rear Bilstein coil overs. What would you consider a "good" deal? $1800 or less? |
J P Stein |
Thanks- I love that Blue monster. Would it change your mind if the 914 had a fully welded in roll cage already done by a well known professional in the area? The cage is not a hack job. Its good. It is also tied to the susp points. Would you overlook the rockers knowing the car is stiff? The car is priced well under the cost of the cage itself, full 911 susp, sway bar, fuel safe fuel cell, two setrab oil coolers, rear 5 lug, rear Bilstein coil overs. What would you consider a "good" deal? $1800 or less? That is, obviously, your quandary. The car's chassis itself I wouldn't trust, flat out. The rockers are scary. The cage, as you describe *now*, does make it interesting, however. If you feel it can be removed without buggering to badly then yes, that is a good price....IF you know the cage was built by a pro....for sure. The car was mis-represented from the git-go it seems or maybe , giving the benefit of the doubt, we didn't have enough info to make a judgment. The problem I have (and you're probably the same) is when I see poor workmanship in one area the rest becomes suspect.....even parts. When you dig into a car to "make it your own" you shouldn't be surprised to find more shi....stuff not up to snuff. Your 9eleben show you to be the kind of guy that is gonna dig & fix. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:15 AM |
