Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
For those who don't know me or the car, I have a '74 914 that is a dedicated AX car. It previously had a high compression 2.7 6-cylinder motor and made 205hp/205ft-lbs at the wheels. This set-up wasn't all that bad considering that it won the 2008 and 2009 914 Shootout events, however the quest for more speed continues.
Here is the car in the 2010 season trim. (IMG:http://www.914world.com/bbs2/uploads_offsite/dragracevws.com-364-1291656786.1.jpg) I have recently sold the 2.7L 6-cylinder engine and all the remaining 914/6 conversion parts. I have used the proceeds to fund the conversion to Subaru power. Now most would say that a Subaru conversion can be done on a budget, however I have found that the money goes flying out the window when doing something like this. Regarding the engine...logical choice would be to go for a EJ257 2.5L USDM STi engine. However, all the SCCA rules for AX are built around displacement which in turn dictates the minimum weight. Therefore, I have gone with a JDM STi version8 Spec-C engine which is a 2.0L, twin-scroll, hand ported/polished, 8500rpm animal. I will get slightly less hp and torque numbers than the 2.5L, but save 150lbs of weight. |
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Sure like the way the SB is being put together Britain. Every step / challenge you've encountered has been solved (very) smoothly.
Can't wait to see that baby run. Whole new experience I'm thinking. (IMG:style_emoticons/default/biggrin.gif) |
Britain Smith |
Sure like the way your putting that car together Britain. Every step / challenge you've encountered has been solved (very) smoothly. Can't wait to see that baby run. Whole new experience I'm thinking. (IMG:style_emoticons/default/biggrin.gif) Thanks Randal...hope to see you again...maybe at the WCR in Medford. -Britain |
Derek Seymour |
Member ![]() ![]() Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California ![]() |
Sure like the way your putting that car together Britain. Every step / challenge you've encountered has been solved (very) smoothly. Can't wait to see that baby run. Whole new experience I'm thinking. (IMG:style_emoticons/default/biggrin.gif) Thanks Randal...hope to see you again...maybe at the WCR in Medford. -Britain This may have been addressed, but I was curious if you planned on fabricating a dead pedal/heat shield. During hard cornering I have always liked the advantage of a dead pedal, but with the radiator line you have there as well I can visualize a bit more complicated yet effective design alternative to the standard dead pedal. |
Britain Smith |
This may have been addressed, but I was curious if you planned on fabricating a dead pedal/heat shield. During hard cornering I have always liked the advantage of a dead pedal, but with the radiator line you have there as well I can visualize a bit more complicated yet effective design alternative to the standard dead pedal. Yep, there will be a fabricated shield over the coolant lines on both sides of the car. The drive side shield will incorporate a dead pedal. -Britain |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:54 AM |
