rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
I just ordered some Clewett spark plug wires for the six and I'm going to change the plugs at the same time. Ignition rotor and cap are only 6 months old. Engine is a stock internal 3.0 with Weber carbs and Mallory multi spark ignition. All my records are still in moving boxes and I haven't pulled the old ones yet so what are the recommended plugs/heat ranges for street driving ? I generally like NGK standard copper plugs but have run copper Bosch in the past. Thanks and happy new year (IMG:style_emoticons/default/beerchug.gif) .
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Reality check!
Early 3.0 engines used one plug, late engines used another. Carbs, especially with "modern" fuels, need a hotter plug than is specified for CIS engines. "R" is for resistor, and most new plugs have that feature. Bosch uses the ":C" designation for non-extended tip, "D" for extended. NGK uses "P" for extended tip, no letter at all for standard tip. A "cold" plug transfers heat away from the tip faster than a "hot" plug. 911s have traditionally run non extended tip plugs. PMO advises running the hottest plug you can get, more or less, and they know quite a bit about 911s with carbs. The book calls for them. However, at some point they changed, probably with the 3.2. The Cap'n |
ME733 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States ![]() |
Reality check! Early 3.0 engines used one plug, late engines used another. Carbs, especially with "modern" fuels, need a hotter plug than is specified for CIS engines. "R" is for resistor, and most new plugs have that feature. Bosch uses the ":C" designation for non-extended tip, "D" for extended. NGK uses "P" for extended tip, no letter at all for standard tip. A "cold" plug transfers heat away from the tip faster than a "hot" plug. 911s have traditionally run non extended tip plugs. PMO advises running the hottest plug you can get, more or less, and they know quite a bit about 911s with carbs. The book calls for them. However, at some point they changed, probably with the 3.2. The Cap'n And while the "R" designation is for resistor plugs (generally)...the "R" in Champion plugs is for a retracted tip..(very retracted) tip...in their race plug series. For resistor plugs, do this, use a multi meter across the ground and electrode. on occasion you can find a plug with no reading or one that is below all the rest. Use the ones that are equal in resistance. This ensures that the plug heat range is equal, and eleminates "phoney" and" mystifing " carburator adjusting and unequal cylinder burn. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:56 AM |
