McMark |
I rebuilt a distributor today and installed a Pertronix unit, and ran into a problem that I never had/noticed before. This was a 039xxx205A distributor and the problem was that the little 'finger' in the bottom right was running into the Pertronix mounting plate. This interference was completely eliminating any vacuum advance.
5 minutes with a file and it was all fixed. If you've got a Pertronix, this would be something to look for and should be visible simply by removing the cap and rotor and jumping in the engine bay with a flashlight. Always learn something new. (IMG:style_emoticons/default/shades.gif) Attached image(s) ![]() ![]() |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,914 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
WE thought that the pertronix and compufire units, when introduced for the type four distributor, were the be all end all, and in the beginning it was: Units that eliminated the messy points condenser, kept the dwell and timing steady, provided better fuel economy, easier cold starts, and smoother idle, AND would hide under the distributor cap.
What we have learned over the years is that it has a high failure rate due to the excessive heat of the air cooled engine, actually reduces the total horsepower of the engine, AND has clearance problems! I would NEVER drive my 914 on a long trip without carrying a set of points and a condenser with me. Too bad we thought that we had a solution. I have one in my Dad's 64 Riviera and it has never failed, but of course that is a water cooled engine with a BIG distributor! |
realred914 |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None ![]() |
WE thought that the pertronix and compufire units, when introduced for the type four distributor, were the be all end all, and in the beginning it was: Units that eliminated the messy points condenser, kept the dwell and timing steady, provided better fuel economy, easier cold starts, and smoother idle, AND would hide under the distributor cap. What we have learned over the years is that it has a high failure rate due to the excessive heat of the air cooled engine, actually reduces the total horsepower of the engine, AND has clearance problems! I would NEVER drive my 914 on a long trip without carrying a set of points and a condenser with me. Too bad we thought that we had a solution. I have one in my Dad's 64 Riviera and it has never failed, but of course that is a water cooled engine with a BIG distributor! near 20 years running a pertronix in my aircooled cars, and no failures. maybe something is wrong causing it to over heat? had plenty of points fail on me however. some even melted!!!! repaired one set of points on a road trip once, with a match book cover. points suck dick, always drifting and needing adjustment. but yes i do keep the old spare points in the spare kit, just is since using pertronix, I have never the need to install the spare points, ever. i am happy with pertronix!!! nice product |
Lo-Fi Version | Time is now: 28th June 2024 - 03:00 PM |
