steeks |
Newbie ![]() Group: Members Posts: 36 Joined: 25-October 10 From: Prescott Valley, Arizona Member No.: 12,310 Region Association: None ![]() |
I was wondering if anyone has replaced the old torsion bar lifting system on the rear trunk lid with modern hydraulic lifters, seems like a pretty simple deal, Pictures anyone?? Thanks.
davesprinkle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None ![]() ![]() |
I'm going to disagree with the conventional wisdom here. The torsion springs work great and they never fail. If you install the shocks, you'll need to cut the sheet metal on your trunk.
The factory got it right with the design of the torsion springs. Don't replace them. |
MoveQik |
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region ![]() ![]() |
If you install the shocks, you'll need to cut the sheet metal on your trunk. The factory got it right with the design of the torsion springs. Don't replace them. The instructions that are included suggest cutting the trunk. I installed mine with the parts included with the kit without any cutting. So easy even I could do it.....so that means it is REALLY easy. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 09:24 AM |
